Thank you. I spent too much time trying to boot from SSD. The 64bit version with WD green 120GB and Geekworm X862 board.
Were you able to get it to work? The Orico adapter is supposed to work is listed at https://jamesachambers.com/raspberry-pi-4-usb-boot-config-guide-for-ssd-flash-drives/ I tried a dark Orico case and it didn’t work. I have no idea if the UGreen adapter will work.
I read on an other thread in this forum of a user upgrading from 5.0 to 5.1, so I hope it will work to upgrade my current installation.
Just noticed that the 32 and 64 bit version is now in 5.2. Anyone tried it?
Edit: 64 bit version online and I’m now running it on a 8gb USB2 stick. Stable for 20 minutes and counting…
Are you running any zigbee devices on your system? I can’t see to pair any, using conbee2, tried zigbee2mqtt & deconz phoscon both.
Used the 5.4 64bit img
I did not used zigbee at the moment, but usb should work… unsure…
Managed to get my conbee2 to work. Surprisingly easy and frustrating, connected it to a USB hub then to the Rpi. SSD boots fine from USB3 port.
Hi
which manual have you used?
Have you installed Hassio Superviced in this way/
Thanks a lot!
Does anyone have any install instruction on how to install HASSIO onto an SSD on a RPi4 please?
Cheers - Works a treat!
