My one
emulated_hue:
type: alexa
listen_port: 8300
Are you looking for Alexa in the developer tools? If you are, I donât think youâll find it at least I didnât. If your getting the xml post back then open your Alexa app and you should see everything there.
You only mention Alexa, you are using a real echo arenât you? If youâre not, itâs never going to work.
From personal experience, once youâve set the echo up, literally just hit discover in the Alexa app and they all appear.
Out of interest, what benefit is haaska adding to your personal set up.
I had skills / SSL setup with Alexa already so setting up HAASKA wasnât that hard. I think at the time I added it because it did more components than emulated hue but now I use it because I have two HA instances running so emulated hue handles one and haaska does the other.
I also use the HA alexa skills to get info sent back to Alexa, like
âAlexa, tell me the status of the front doorâ
âAlexa, tell me everything that is openâ
or
âAlexa, tell me the location of Johnâ
Thanks, sounds like stage 2
my alexa today stop show all device form HA
