My HASSIO running on RPi 3B+ is very slow. Restarting is takes 5 minutes at least. Even stepping away and reloading a page of the UI requires a very slow reconnect. I have been removing components and automatons to try to isolate the bottleneck. In looking at the log I have nothing but a media center updated, the sun sensor and THIS:
2018-07-12 11:38:54 INFO (MainThread) [homeassistant.components.http.view] Serving /api/ to 172.30.32.2 (auth: True)
I don’t recognize that IP address, and can’t find any information about it. Does anybody know anything about it? FYI when I saw it, I closed down port forwarding on my router as well.
Could it be DuckDNS? If so, why can’t I find any confirmation of that researching the IP addy?
yes, because thats where the author of the CC posted about his component…
btw those 172. ip addresses are so-called internal ip addresses on your network
if you’re running it, you should have a sensor.last_succesful_authentication:
explicitly in configuration.yaml, and don’t rely on discovery to find hassio, many hassio related issues are solved. Including Hassio always being in the sidebar. (ive had it disappear without any clear hint as to why, only got the config-error notification)
