bessarabov
(Ivan Bessarabov)
May 21, 2020, 11:27am
1
Some time ago I have created a small cusom lovelace card — https://github.com/bessarabov/animated-consumption-card
Here is how it looked before the 0.110.0:
And here is how it looks with 0.110.0:
I know that in 0.110.0 some changes were implemented how the frontend is working with mdi icons.
What is the way one should use to change the size of mdi icons? I would like to find a way to specify the size that is working in version before 0.110.0 and after 0.110.0.
The way that I was using is just to use css width & height on the element with icon:
html:
<ha-icon class="acc_icon" icon="mdi:electron-framework"></ha-icon>
css
.acc_icon {
height: 80px;
width: 80px;
border: 1px solid black;
border-radius: 100px;
padding: 22px;
color: var(--primary-text-color);
border-color: var(--primary-text-color);
ludeeus
(Ludeeus)
May 21, 2020, 11:30am
2
--mdc-icon-size: 80px; for 0.110+
for pre and post 0.110 this might work:
height: 80px;
width: 80px;
bessarabov
(Ivan Bessarabov)
May 21, 2020, 11:44am
3
Thank you! Adding --mdc-icon-size:⋅80px; made a situation a bit better:
But this is still not the way I expect this card to work. I will try to find some workaround to fix it.
Maybe this is the same problem that is described in https://github.com/material-components/material-components-web-components/issues/1071
I will try to find some solution, but if will be glad to hear some recommendations if anybody has them.
bessarabov
(Ivan Bessarabov)
May 21, 2020, 12:02pm
4
This is the fix that I’ve implemented — https://github.com/bessarabov/animated-consumption-card/commit/9ce699a5d7e3bfae3deedbd8450fada29baeb784
I have tested it with 0.110.0 and 0.107.4. On both versions the card is working as execpeted.
Where did you implement this bit of code?
