Well, I have not installed it in the wall just yet. I power it up and trying to learn how to use it first. Kind of hard not seeing immediate results, but watching the entity. This is my first experience with a dimmer.
My question is after installing the zwave dimmer switch, there are two entities.
Why am I getting a query_stage Protocolinfo? Why are the two switches for one switch?
Here are some screenshots showing what I am seeing.
I installed one of these switches today. When I included the switch, there was a zwave and light device added as expected. I suspect that the first time you included the switch, it did not complete the inclusion and then made the second entries when it concluded. I suggest you delete the existing entries and do the inclusion again.
@ceh Thnaks, I hope to mess with it this weekend, you know Holidays. I just did not want you to think you wasted your time with a response, I will get back with results. This is my first zwave, I did not know there would be two entries. So I would assume, a two switch device would have 3? One for the zwave and one for each switch?
When adding a zwave device, you should get two items. A zwave… and then another device for whatever the item is, such as lock, sensor, switch, or in the case of the Zen27, light.
Actually, it is working on the bench. Just the “partial” thing was confusing. I will try and re-adopt it again. I hope to install it the Saturday while I have light with the power off.
Thanks again.
