What is the sensor data format?
I have a device that is publishing a JSON string of various status values.
In my sensors.yaml include file, I have this entry:
  - platform: mqtt
    force_update: true
    state_topic: "garden2/statusJson"
In Developer Tools, States, I can see the sensor, but the data is the whole JSON string:
{"temp":"77.68","wet":"114","raw":"861","rssi":"-66","sleep":"10"}
How can I split it into attributes to use in an automation, for example?
(I am guessing that I need to use a template, but how?)
Use the value template option. e.g.
  - platform: mqtt
    json_attributes_topic: "garden2/statusJson"
There is an example here: https://www.home-assistant.io/integrations/sensor.mqtt/#json-attributes-template-configuration
Also please format your pasted code.
Thanks a heap- I am glad it was this simple.
