I’m curious how you can link to that thread, quote that exact line and not continue reading that same post. He actually tells you the full steps.
Full steps:
- in homeassistant custom_components folder create a folder named
climate- then homeassistant
custom_components/climatefolder:
wget https://raw.githubusercontent.com/home-assistant/home-assistant/master/homeassistant/components/climate/tuya.py- edit the custom_component as described above
So based on this detailed guide, you create a custom_components folder, then inside that you create a climate folder, then you need to copy the tuya.py file from that link into that folder (wget is a command line option to grab that file, but you can manually browse to it, copy the contents and create the file manually.
