----configuration.yaml-----
group: !include groups.yaml
script: !include scripts.yaml
--------scripts.yaml--------
light_on_change: !include light_on_change.yaml
--------light_on_change.yaml------
sequence:
- data:
packet:- JgDYAAABJ5MTERI3FBESEhISEhITEhI3ExESEhMSEjcT
alias: Light Change
Error:
2018-02-03 17:33:15 INFO (MainThread) [homeassistant.setup] Setting up group
2018-02-03 17:33:15 ERROR (MainThread) [homeassistant.config] Invalid config for [script]: [data] is an invalid option for [script]. Check: script->script->light_on_change->sequence->0->data. (See /home/homeassistant/.homeassistant/configuration.yaml, line 70). Please check the docs at https://home-assistant.io/components/script/
2018-02-03 17:33:15 ERROR (MainThread) [homeassistant.setup] Setup failed for script: Invalid config.
