I will move from a Pi to a mini PC (Core 2Duo E8400 + 4GB RAM) and I would like your opinion on the ideal OS to use. i will docker, and CLI only OS would be fine for me.
What do you think?
What do you think?
Debian 10 works great for me.
Debian 10 is the only supported OS if you’re looking at using the Supervised install method, and a good choice regardless.
thanks for your reply … so I should GO to debian with docker since I am coming from docker on pi? (I would like to restore my current config). Also should i go for a 32bit or 64 bit OS?
Are you aware of a step by step install tutorial ?
EDIT: Found this tutorial … will follow it and update you
Centos8 appstream works great for me…
