Recently I moved from another HA System to Home Assistant. I have been using Node Red to do a lot of my previous automations and honestly I am enjoying it so far. But I have a question and I could be over or under thinking it in general.
My Goodnight Automation pretty much shuts down just about everything in the house. I have a lot of Zwave devices and pretty much I added nearly anything I could think of needing shutting down. The reverse for Waking up.
But my question is I have an Input Boolean with Awake and Sleep. I use the entity: state to watch for the change and act accordingly for sleep or awake. But I have all this crammed into one big sleep automation.
I am no wondering since I have my Node Red Flow Tabs setup for each room doesn’t it make more sense to have a State node setup for each room only firing off the sleep / awake for that room or keep it all jammed into one big automation.
I guess I am thinking of two things … Performance of the Pi but also organization of understanding it should I need to revisit it in a year or two.
Any help or suggestions would be great
Thanks guys
