I have old onkyo tx-sr500 receiver, Onkyo SKW-100 subwoofer with 4 Onkyo speakers, what needed in order to connect it to HASS?
One possibility is a Harmony hub so you can control the Onkyo, and then use one of the Onkyo inputs for some HA supported media player that has audio out. An Echo Dot maybe.
Thanks for the suggestion. I think echo dot doesn’t allow local music, so this setup won’t allow me to play local music files, right?
I have an old Onkyo TX-SR600 (i think it is…) which I control with a Broadlink RM3mini and a power monitoring smart plug. The RM3mini sends it IR signals and the smart plug allows HA to know if its on or off based on power consumption. It works perfectly. I use this to create a media_player entity for it.
For music I have a Chromecast Audio plugged into one of the inputs. HA automatically turn on the amp and selects the correct input whenever I stream to the Chromecast. It turns off the amp when streaming is stopped as long as I haven’t subsequently turned on the TV, since that would suggest I am stopping music to watch TV. So instead HA then sends the amp a signal to switch to the TV input. You can stream local music to Chromecasts
My answer would have been different if you’d said that from the beginning Using hass to play local mp3s is a pretty niche application. I use iTunes and the iTunes component for that but it has a some minor limitations. Most people stream their music.
Use chromecast seems to be a good option. How do you switch input of the receiver from HASS?
Via the IR blaster
I had this receiver (ONKYO TX-SR500) but lost the RC, do any of you by any chance have the list of the IR commands? power, source and volume will be appreciated! thanks!
Here is what I have for my Onkyo. It’s a different model but hopefully the codes will be the same.
"manufacturer": "Onkyo",
"supportedModels": [
"Unknown"
"supportedController": "Broadlink",
"commandsEncoding": "Base64",
"commands": {
"off": "JgBIAAABKJEUERQ2FBAUERQ2FBAUNhQ2FBAUERQ2FDUUERQ2FDYUEBQ2FDYUNRQRFBEUEBQ2FBEUEBQRFBAUNhQ2FDYUEBQ2FAANBQ==",
"on": "JgBMAAYABD8AASiSFBEUNRQRFBEUNRQRFDYUNRU1FBEUNhQ1FBEUNhQ1FBEUERQQFDYUERQQFBEUEBQRFDYUNRQRFDYUNRU1FDYUNhQADQUAAAAAAAAAAAAAAAA=",
"previousChannel": "JgBIAAABKJIUEBQ2FBEUEBQ2FBETNhQ2FDYUEBQ2FDYUEBQ2FDYUERQ1FBEUERMRFBEUEBQRFBETERQ2FDYUNRQ2FDYUNhQ1FAANBQ==",
"nextChannel": "JgBIAAABKJEVEBQ1FRAUERQ1FBEUNhQ1FTUUERQ2FDUUERQ2FDUUERQRFBAUERQRExEUERQQFBEUNhQ1FDYUNhQ2FDUUNhQ2FAANBQ==",
"volumeDown": "JgBQAAkADMILAAzsAAEqkRQRFDYUEBQRFDYUEBQ2FDYUNRQRFDYUNhMRFDYUNhQQFDYUNhQQFBEUERQQFBEUEBQRFBEUNRQ2FDYUNhQ1FDYUAA0FAAAAAAAAAAA=",
"volumeUp": "JgBIAAABKIwaERM2FBEUERM2FBEUNhM2FDYUERM2FDYUERQ1FDYUERQQFDYUERQQFBEUERMRFBEUNhMRFDYUNhM2FDYUNhQ2EwANBQ==",
"mute": "JgBIAAABKJIUEBQ2FBEUEBQ2FBETNhQ2FDYUEBQ2FDYUERM2FDYUERQ1FBEUNhQQFBEUERMRFBEUEBQ2FBEUNRQ2FDYUNhQ1FAANBQ==",
"sources": {
"ChromeCast Audio": "JgBQAAABKJIUEBQ2FBEUEBQ2FBETNhQ2FDYUERM2FDYUERM2FDYUERM2FBEUERM2FBEUERMRFBEUEBQ2FDYUERM2FDYUNhQ2EwAE8gABKEkTAA0FAAAAAAAAAAA=",
"Video 1": "JgBIAAABKJEUERM2FBEUERM2FBEUNhM2FDYUERQ1FDYUERQ2EzYUERQ2EzYUNhQ2FBETERQRExEUERQRExEUERQ1FDYUNhQ2EwANBQ==",
"Tuner": "JgBIAAABKJEUERQ1FBEUERQ1FBEUNhQ1FDYUERQ2EzYUERQ2FDUUERQ2FDUUERQ2FBETERQRFBAUERQREzYUERQ2EzYUNhQ2FAANBQ==",
"DVD": "JgBQAAABJpMVEBQ2ExITERQ2ExESOBM3ExIRExM3EjgTERM3EjgSEhMSEhITNxM3FBETERITETkSNxQ2EhMTERQ2EjgTNhMSEgAFGQABJkoUAA0FAAAAAAAAAAA=",
"Phono": "JgBIAAABJpQSEhM3ERQRExI4EhITNxI4EjgSEhI4EjgSEhM3EzcSEhMSEjgSEhI4FBETERMSEhMSNxMSEjgTERM3EjgSNxM3EwANBQ=="
The ‘chromecast audio’ input is actually the ‘CD’ input on the amp.
