I’ve just installed HASS on my Synology using Docker and have successfully added the Aeotec Zstick gen5 dongle. I’ve added nodes to my setup, but I have not yet been able to add a network key.
I simply can’t find an openzwave folder anywhere on my syste,. I don’t know enough to reason it out.
Do I have to install an openzwave container? Doesn’t adding nodes through the hass interface prove it actually works? Does it have to run in order for it to work?
Where should I put the options.xml file? How does hass know where to find it?
I have a zwcfg_0* file in my hass config folder. Does that tell me anything?
Sorry for the newb questions. I’m learning as I go here.
I’m not sure if it’s the same for your setup but on my raspberry pi the open zwave options.xml can be found in ~/srv/homeassistant/src/open-zwave-control-panel/config you will then need to copy the options.xml file into your HA config folder. Then if you’re using secure nodes you’ll need to uncomment the networkKey section then re-add your nodes. The options file network key is only really needed if you’re using secure connections.
