What’s the best method to install home assistant supervised and Homebridge on the same raspberry pi?
There is only one method. Install home assistant supervised as documented. Or don’t install supervised but install HA OS as documented.
So, I cant
What you asked for is not supported
Not supported is not the same as not possible. Having said that I don’t kniw what homebridge is or how to install it.
After a quick google, the answer would be docker.
Which is why I just said, it wouldn’t be supported.
I don’t agree with a number of the things the devs say, but they generally have a point and in this case I absolutely agree.
Don’t piss in the pot you drink out of
All i’d day is "worth a try, but if ha has troubles, be prepared to install homebridge on another machine. "
Homebridge used to be a community addon (requires a ‘supervised’ version of home assistant) It no longer appears in the home assistant addon store as the core HomeKit integration now has all this functionality built in.
Given that this core functionality is available, why do you need the Homebridge addon?
Basically nest. Homebridge has nest
I’m guessing you’ve seen the alternatives like badnest?
No, I haven’t, thank you
Do you know ifRING DOORBELL cameras work?
Thank you…
