Yesterday, buy mistake, I run a command line which removed all my home assisatnt folder
That is not an issue. I have a backup, or more accurate, I have a backup of most of the things. It was relatively very easy to restore the configuration. Mainly because 95% of the configuration is in YAML files. It was very easy to restore.
The 5% that left are all the configurations that can be done only from the UI. This 5% required much much more time to recover (untill I find what is missing and one by one configure them).
What are the files that need to be saved to allow faster recovery of all these inetgrations?
I hope that the Home Assistant team will reconsider and will keep the option to configure via YAML files, or at least allow integrations that do both. I assume it is not for all, but I think there are enough pepole who prefer this method.
