Hi all,
I’m new to Home Assistant and also in this forum, I did check the protocol but if I am not doing something via protocol, apologies in advance and I would love to hear what I should do differently.
I am currently building a new home entirely under my own management. In this home, I would like to lay a foundation with Home Assistant.
I’ve been reading blogs, forums and checking video’s for a while now and trying to determine the best basic setup for my specific situation. Because of that I have a few questions on different topics, hopefully you guys with experience can help me! Just for your information, I have little/no knowledge of programming.
- Are there any basic design things that you recommend to include already during the construction of my house?
- Home network setup: Thinking of going for a router/firewall (any good arguments for which of the two to go?), switch (normal ports + POE ports), Access points, having Cat6 cabling. Obviously I still need to figure out what specific hardware I’m going for but any comments on the basic setup?
- Home Assistant setup: By now I have purchased a mini PC and SkyConnect, is it best to start installing HAOS on this mini PC or go straight for Proxmox or something similar? (As I understand it, installing HAOS directly is more reliable, perhaps for inexperienced users, than via a VM) Right now I don’t know what I would need to run multiple VMs on my mini PC for. In the end I would like to integrate roughly the following things in Home Assistant: Smart relays, temperature/motion/door sensors, probably energy management (heat pump, solar panels).
- Camera system: I would like a Reolink doorbell and 2 or 3 cameras, all POE. I want to use these for simple observation so not specifically if Uncle Rick had walked by. With this, would it suffice to purely install a Reolink NVR or is it almost mandatory to also install Frigate or something similar with this?
- Relay switches: I would like to use traditional light switches but turn these into smart switches and in addition I would also like smart outlets by using smart relays. In doing so I also want to be able to monitor energy usage for some of these, I have a Neutral wire available. So far the Shelly 1PM seems the most suitable to me (just thought I’d better use a device that didn’t go via wifi but haven’t found any better alternatives). What is your advice in this?
- I think Aqara FP2 sensors are interesting but don’t like them needing a power socket, are there/will there be variants on battery or should I better foresee power sockets?
- Any other important attention points you would bring to me?
Sorry in advance if things are not clear and thanks for the feedback. I hope you guys can help me!
