Hi, what do you guys say which operating system I should run on my Linux server. It looks like a VM is better here.
What do you suggest such as Ubuntu, Linux Mint etc.?
THANK YOU for your support
If you run a VM, use the Home Assistant OS, it’s the easiest for beginners.
Otherwise Debian 11.
Proxmox VE
Snapshots and easily backups
Exactly one Proxmox server has been running for several years…iobroker, node-red, motioneye, unifi, phoscon…
That’s why I thought I could also install home assistant on a proxmox vm.
Ubuntu, Debianb11 (Thank you for the tip)
It doesn’t matter which Linux distribution I use… should be small & fast :))
As I said, if you install it in a VM, then install the Home Assistant OS. It’s the easiest to get started and you don’t need to maintain an additional OS.
After installing the Debian 11 VM, do I still need to create a VirtualBox/KVM/Vmware workstation? Or where can I find exactly the right variant?
Install the Home Assistant OS and save yourself all the hassle
What do you mean exactly? Do you mean I should install the HA OS on my Proxmox VM?
You create a new VM and use the Home Assistant OS image as the operating system instead of Debian or Ubuntu or whatever
OK, but how to do it? I only found the instructions from above. Do you happen to have a link or a ToDo
THANKS …Yes exactly, that’s my tutorial from above. But which one do I need to use for Proxmox Debian VM.
Is this then a standalone system and not a virtual machine running Debian 11?
HA OS is an stand-alone system you can run directly in proxmox.
oh yes i have seen a proxmox lxc
bash -c "$(wget -qLO - https://raw.githubusercontent.com/tteck/Proxmox/main/debian11_container.sh)"
Thanks i used this script
bash -c "$(wget -qLO - https://raw.githubusercontent.com/tteck/Proxmox/main/pve6_ha_container.sh)"
Now the lxc is locked ?
qm unlock vm-id
did not unlock??
You ran a pve6 script, you’re on pve7
remove 107 and run the correct script
wait for the script to finish
very bad day for me…
i have installed lxc and see login
what is the password and how to continue, because a HA login page does not come yet either
http://IP:8123/
