What can I replace input_text with to save more than 255 characters.
I read the documentation and all the topics I found on the forum. I understand that input_text cannot contain more than 255 characters.
There are input_texts that write different information depending on the if branching. Branching can sometimes reach 2-3 nestings. Something like this:
if condition1
then
if condition2
then
if
condition3
then
input_text_one: value 1
else
input_text_one: value 2
else
if condition4
then
if
condition5
then
input_text_one: value 4
else
input_text_one: value 5
else
etc...
In some cases, errors are written that the server returns. Errors are longer than 255 characters, and unknown is written to input_text.
This information is not used on the frontend, the information is collected in a message and sent. It is also used in other automations.
message: >
Response to request:
Error_one: {{ states('input_text.one_message_telegram_system') }}
The question is, what can I replace input_text with so that the information fits more than 255 characters and is available everywhere?
I tried using a variable, it can store more information, but it does not work in more than one block.
petro
(Petro)
November 28, 2024, 3:28pm
2
You’d have to use a template entity and move all your logic into an attribute on the template entity. Or make a responding script that calculates your response on the fly.
I understand you, Petro.
I thought about it, but I hoped there was another way.
P.S. It’s strange why they don’t make a global variable.
Can you tell me how to write down or change the value of an attribute in automation?
petro
(Petro)
November 28, 2024, 5:36pm
5
You can’t, template entity. Post your automation and I’ll show you how to turn it into a template entity’s attribute
Currently used for input_text
Everything works fine, except when an error occurs when more than 255 characters
alias: Sending values
triggers:
- trigger: time
at: "21:00:00"
conditions:
- condition: and
conditions:
- condition: template
value_template: "{{ (now() + timedelta(days=0)).day == 20 }}"
value_template: "{{ has_value('sensor.me_allow_send_data') }}"
enabled: true
actions:
# There are 4 such modules so far, they are identical.
# I didn't insert everything
- if:
- condition: and
conditions:
value_template: >-
{% set difference =
(state_attr('sensor.sau_water','vals')[0] | float |
round(0)) - (states('sensor.me_water') | float | round(0))
{% if difference | float < 15
%}true{%else%}false{%endif%}
then:
- action: rest_command.one_water_request
metadata: {}
data: {}
response_variable: status_response_one_water
enabled: true
- if:
value_template: "{{ status_response_one_water['status'] == 200 }}"
then:
- action: input_text.set_value
metadata: {}
value: >-
"Send \[ID={{state_attr('sensor.me_water','id') }}]
{{state_attr('sensor.sau_water','vals')[0] | float |
round(0) }}
{{state_attr('sensor.sau_water','unit_of_measurement') }}
{{now().strftime("%m.%Y") }}"
entity_id: input_text.one_water_message_telegram_info
metadata: {}
value: Sent successfully
entity_id: input_text.one_water_message_telegram_system
else:
metadata: {}
value: Sending error. Information in system chat
metadata: {}
value: "{{ status_response_one_water['content']['message'] }}"
else:
metadata: {}
value: >-
"Warning! Very large values:" "{{
(state_attr('sensor.sau_water','vals')[0] | float | round(0))
- (states('sensor.me_water') | float | round(0)) }}"
"{{state_attr('sensor.sau_water','unit_of_measurement') }}"
"Sending error"
# Next, the information is sent.
- action: notify.telegram_cannel_info
metadata: {}
message: >
*Object {{ state_attr('sensor.sau_api_object', 'house')}},{{state_attr('sensor.sau_api_object', 'number') }}*
Send one water {{states('input_text.one_water_message_telegram_info') }}
Send two water {{states('input_text.tho_water_message_telegram_info') }}
Send three water {{states('input_text.three_water_message_telegram_info') }}
Send four water {{states('input_text.four_water_message_telegram_info') }}
- action: notify.telegram_cannel_system
metadata: {}
message: >
Server response:
One water = {{ status_response_one_water['status'] }}
Error: {{ states('input_text.one_water_message_telegram_system') }}
Two water = {{status_response_two_water['status'] }}
Error: {{ states('input_text.two_water_message_telegram_system') }}
Three water = {{status_response_three_water['status'] }}
Error: {{ states('input_text.three_water_message_telegram_system') }}
Four water = {{status_response_four_water['status'] }}
Error: {{ states('input_text.four_water_message_telegram_system') }}
mode: single
So I want to replace input_text with something that contains more characters.
kartcon
(Art Davis)
November 28, 2024, 9:24pm
7
There are two integrations that create sensors that can be used as global variables. Take a look at
https://github.com/snarky-snark/home-assistant-variables/blob/6fd48b28b785bc32a8a53c36a28d55d73fc5d4a8/README.md
and
https://github.com/enkama/hass-variables
I use both, the second allows yoy to create a history of the value if that is something you need.
Art
