I’m looking for a water/flood sensor that will completely work with HASS. I have the Fibaro flood/water sensors, and while they connect fine, it’s not reporting anything through to HASS aside from temperature despite OZW log showing events during water detection.
I’ve done a ton fo searches on this and found various threads which corroborate that the Fibaro sensor just doesn’t work. Some people have tinkered in the guts of the device settings, but the results have been inconsistent.
Which water sensors are known to work 100% with HASS? I’m trying to put sensors in several places to detect water leaks, and some of them I want to ultimately control a shutoff valve at my water main when there is a leak.
I have one of the Aeotec ones that works fine (after I changed one of the reporting value settings through the zwave control panel–it wasn’t reporting anything originally)
On HASS it showed this description for Report Type to Send: To set which command will be sent to the associated nodes when the Water Sensor is triggered. Bitsets: 1 -> Battery 4 -> Sensor Binary 8 -> Basic Set 12 -> Alarm Default setting: 0x100 (Basic Set) OZW Ideal Setting: 0x1011 (Battery, Sensor Binary Report, Alarm)
so I just converted 0x1011 to an integer, which is 4113
Did you change anything in the zwave settings? Hass shows a bunch of sensors but not sure which is the actual leakage as I only see a value, not on/off
Hi
I think about but water sensors Neo Coolcam by WIFI model NAS-WS02W. Is any chance to integrate it with Home Assistant ? It is probably on ESP8266. Maybe any chance to change firmware in this on custom like Tasmota ? But how configure this firmware to detect leak. Please help…
How did you connect Neo coolcam zwave water sensor to Z-wave JS?
I tried to do this more than few times, no luck.
Everything else is connected to Zwave network without any problem
TY
