Well done.
I thought I’d done it the hard way ![:smile: :smile:](https://community.home-assistant.io/images/emoji/twitter/smile.png?v=12)
Enjoy recording your remote codes
Edit:
Just as I hit submit, I realised there’s a better approach to sending the codes… They should be buttons rather than the switches I’ve been using.
![image](https://community-assets.home-assistant.io/original/4X/1/c/c/1ccf15ee598f5eec600867ae68d40d4d200b6b8e.png)
The toggles never made much sense, but they did work OK.
Better version:
esphome:
friendly_name: IR_Blaster
bk72xx:
board: cb3s # https://docs.libretiny.eu/boards/cb3s/
#bk72xx:
# board: generic-bk7231n-qfn32-tuya
# <<: !include .common.yaml
logger: # Enable logging. https://esphome.io/components/logger.html
level: INFO # NONE, ERROR, WARN, INFO, DEBUG (Default), VERBOSE, VERY_VERBOSE
api: # Enable Home Assistant API.
encryption:
key: !secret api_encryption_key
ota:
password: !secret ota_password
safe_mode: True
wifi: # WiFi connection details. Without domain:, defaults to .local. https://esphome.io/components/wifi.html
ssid: !secret wifi_ssid
domain: .home
ap: # Enable fallback hotspot (captive portal) in case wifi connection fails
ssid: "${friendly_name} Fallback"
password: !secret fallback_password
captive_portal:
# Enable web server, browse to http://HOSTNAME or http://IP_Address. https://esphome.io/components/web_server.html
#web_server:
# port: 80
# include_internal: true # include intrnal entities
# local: true # Load everything locally rather than over the web
# # version: 1
- platform: wifi_signal # Reports the WiFi signal strength in dB. https://esphome.io/components/sensor/wifi_signal.html
name: "WiFi Signal dB" # Uncomment to show signal DB in HA
update_interval: 60s # Report signal every minute
entity_category: "diagnostic"
device_class: "signal_strength"
disabled_by_default: true # Shows entity in HA, but disabled by default
internal: true
- platform: copy # Reports the WiFi signal strength %
source_id: wifi_signal_db
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "%"
# - platform: uptime
# id: uptime_seconds
# # update_interval: 10s
# # internal: true # Uncomment to leave internal and not send to HA
# name: "Uptime"
# entity_category: "diagnostic"
# disabled_by_default: true # Shows entity in HA, but disabled by default
# Sync time with Home Assistant
time:
- platform: homeassistant
light:
- platform: status_led # Used as a status LED during errors, and status_light when OK. https://esphome.io/components/light/status_led
pin: P8
# name: Status LED # Uncomment to show in HA
icon: mdi:led-on
binary_sensor: # Button, https://esphome.io/components/binary_sensor/gpio
- platform: gpio
pin:
number: P6
inverted: true
mode:
input: true
pullup: true # Holds it high/off, otherwise it flutters on/off
# icon: "mdi:button-pointer"
# internal: true # Hides button from HA
on_press: # Switch LED on/off as a test
- light.turn_on: status_light
on_release:
- light.turn_off: status_light
# # Home Assistant sensor to store received remote command data
# text_sensor:
# - platform: template
# name: Learned Command
# icon: mdi:remote
# id: learned_command
remote_receiver:
pin:
number: P7
inverted: true
mode:
input: true
pullup: true
tolerance: 25
# dump: all
# dump: pronto
dump: raw
# dump: samsung
# on_samsung:
# - if:
# # If Samsung code is received
# condition:
# lambda: 'return id(remote_learn_switch).state;'
# then:
# - lambda: |-
# id(remote_learn_switch).publish_state(false);
# std::string log_output = "Samsung: Data = 0x" + esphome::format_hex((uint32_t)x.data) + ", nbits = " + esphome::to_string(x.nbits);
# id(learned_command).publish_state(log_output.c_str());
# - delay: 80ms
# - light.turn_on: status_light
# - delay: 500ms
# - light.turn_off: status_light
# # If Sony code is received
# on_sony:
# - if:
# condition:
# then:
# - lambda: |-
# std::string log_output = "Sony: Data = 0x" + esphome::format_hex(x.data) + ", nbits = " + esphome::to_string(x.nbits);
# - delay: 80ms
# - delay: 500ms
remote_transmitter:
pin: P26
# Infrared remotes use a 50% carrier signal
carrier_duty_percent: 50%
button:
- platform: restart
## Home Assistant controlled switch - to enable "learning mode"
# name: Learn Command
# id: remote_learn_switch
# icon: mdi:remote
# optimistic: true
# IR codes to send from HA:
# FAN
icon: mdi:fan
on_press:
- remote_transmitter.transmit_raw:
carrier_frequency: 38kHz
code: [1155, -438, 1250, -403, 437, -1250, 1291, -396, 1282, -406, 437, -1260, 428, -1250, 437, -1264, 434, -1240, 437, -1250, 1295, -393, 469, -7947, 1303, -406, 1291, -397, 468, -1219, 1281, -413, 1275, -406, 437, -1250, 441, -1250, 434, -1251, 437, -1263, 425, -1250, 1281, -410, 468, -7948, 1299, -406, 1282, -406, 447, -1240, 1250, -438, 1263, -424, 438, -1278, 409, -1254, 437, -1266, 418, -1250, 444, -1247, 1247, -438, 437, -7979, 1281, -428, 1250, -437, 438, -1263, 1237, -437, 1250, -438, 419, -1268, 407, -1281, 406, -1294, 425, -1250, 406, -1294, 1237, -438, 406]
- delay: 60ms
icon: mdi:fan-off
on_press:
code: [1164, -389, 1288, -399, 469, -1266, 1232, -414, 1275, -409, 441, -1274, 444, -1243, 437, -1267, 420, -1253, 434, -1267, 420, -1253, 1247, -7185, 1250, -441, 1246, -379, 472, -1274, 1266, -390, 1284, -403, 469, -1266, 421, -1253, 434, -1253, 437, -1246, 441, -1247, 439, -1264, 1240, -7165, 1271, -399, 1298, -390, 468, -1253, 1252, -417, 1265, -412, 462, -1250, 442, -1248, 435, -1253, 434, -1266, 421, -1256, 431, -1254, 1249, -7167, 1265, -444, 1243, -410, 481, -1233, 1287, -400, 1297, -390, 437, -1254, 434, -1266, 421, -1253, 434, -1249, 446, -1255, 440, -1240, 447]
- delay: 60ms
icon: mdi:fan-chevron-up
on_press:
code: [1188, -403, 1298, -389, 437, -1250, 1291, -396, 1283, -403, 438, -1259, 428, -1249, 1281, -406, 437, -1256, 431, -1249, 438, -1259, 427, -8011, 1267, -406, 1284, -406, 434, -1250, 1280, -407, 1294, -392, 438, -1249, 437, -1288, 1243, -437, 406, -1291, 396, -1281, 406, -1281, 409, -8006, 1268, -437, 1249, -438, 406, -1290, 1240, -437, 1253, -434, 406, -1280, 406, -1281, 1259, -428, 406, -1280, 406, -1291, 409, -1268, 406, -8016, 1288, -410, 1249, -438, 406, -1293, 1237, -437, 1250, -437, 406, -1291, 396, -1280, 1263, -424, 406, -1281, 437, -1250, 416, -1270, 438, -7994, 1252, -437, 1259, -428, 406, -1280, 1260, -427, 1250, -437, 437, -1260, 427, -1249, 406, -1281, 404, -1293, 427, -1250, 437, -1263, 393, -8010, 1267, -437, 1255, -438, 431, -1250, 1249, -534, 1166, -424, 406, -1281, 406, -1294, 424, -1249, 438, -1259, 396, -1281, 437, -1250, 409, -8007, 1267, -437, 1250, -437, 406, -1291, 1239, -438, 1252, -437, 406, -1278, 406, -1295, 399, -1283, 396, -1281, 406, -1291, 396, -1281, 409, -8105, 1176, -462, 1218, -469, 375, -1286, 1246, -470, 1217, -438, 406, -1292, 396, -1282, 406, -1295, 393, -1281, 406, -1282, 416, -1272, 406]
- delay: 60ms
# Fish light
name: Fish light On/Off
icon: mdi:wall-sconce-flat-outline
on_press:
code: [9956, -4437, 680, -1594, 687, -538, 650, -531, 656, -531, 656, -532, 659, -528, 656, -1593, 688, -531, 688, -531, 656, -1593, 688, -1624, 688, -1597, 684, -1593, 688, -1611, 701, -500, 656, -1628, 684, -1593, 688, -531, 656, -531, 657, -1593, 691, -1590, 688, -531, 656, -535, 653, -531, 687, -500, 656, -1706, 607, -1593, 689, -533, 653, -531, 657, -1595, 689, -1591, 688, -1632, 681]
- delay: 60ms
name: Fish light 12:00
icon: mdi:update
on_press:
code: [9777, -4469, 646, -1704, 577, -594, 594, -597, 628, -556, 625, -562, 625, -563, 635, -1681, 590, -594, 625, -575, 612, -1656, 625, -1708, 621, -1643, 622, -1711, 601, -1657, 676, -511, 625, -1688, 625, -585, 602, -563, 625, -1656, 647, -1665, 625, -1679, 603, -593, 625, -563, 594, -600, 660, -1646, 625, -1682, 600, -593, 594, -594, 656, -545, 643, -1682, 630, -1651, 599, -1688, 687]
- delay: 60ms
# Samsung TV
# icon: mdi:check
icon: mdi:keyboard-return
on_press:
- remote_transmitter.transmit_samsung:
data: 0xE0E016E9
- delay: 60ms
icon: mdi:power
on_press:
data: 0xE0E040BF
- delay: 60ms
icon: mdi:volume-mute
on_press:
data: 0xE0E0F00F
- delay: 60ms
icon: mdi:menu
on_press:
data: 0xE0E058A7
- delay: 60ms
icon: mdi:undo
on_press:
data: 0xE0E01AE5
- delay: 60ms
icon: mdi:arrow-up-bold-outline
on_press:
data: 0xE0E006F9
- delay: 60ms
icon: mdi:arrow-down-bold-outline
on_press:
data: 0xE0E08679
- delay: 60ms
icon: mdi:arrow-left-bold-outline
on_press:
data: 0xE0E0A659
- delay: 60ms
icon: mdi:arrow-right-bold-outline
on_press:
data: 0xE0E046B9
- delay: 60ms
icon: mdi:exit-to-app
on_press:
data: 0xE0E0B44B
- delay: 60ms
icon: mdi:tools
on_press:
data: 0xE0E0D22D
- delay: 60ms
icon: mdi:information-variant
on_press:
data: 0xE0E0F807
- delay: 60ms
# PC
# yellow
icon: mdi:television-ambient-light
on_press:
- remote_transmitter.transmit_pronto:
data: "0000 0073 0000 0020 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 0020 0020 0010 0010 0010 0010 0020 0020 09DD"
- delay: 60ms
name: Kodi Clean Library
icon: mdi:kodi
on_press:
code: [2516, -921, 406, -468, 438, -437, 406, -937, 406, -906, 1315, -903, 406, -500, 406, -468, 406, -469, 406, -500, 406, -469, 406, -500, 405, -469, 406, -467, 408, -468, 438, -468, 844, -468, 437, -469, 406, -469, 406, -923, 388, -500, 407, -468, 409, -466, 437, -469, 843, -937, 406, -469, 406, -468, 844, -937, 437, -454, 858, -906, 406, -468, 406, -500, 406]
- delay: 60ms
# Guide
name: Kodi Refresh Library
icon: mdi:refresh
on_press:
data: "0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0020 0010 0010 0020 0010 09CD"
- delay: 60ms
icon: mdi:pause
on_press:
data: "0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0020 0010 0010 0010 0010 0010 09BD"
- delay: 60ms
icon: mdi:undo
on_press:
data: "0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 0010 0010 09CF"
- delay: 60ms
# icon: mdi:check
on_press:
data: "0000 0071 0000 0020 0061 0021 0010 0011 0010 0011 0010 0021 0010 0021 0030 0021 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0020 0011 0010 0011 0010 0011 0010 0021 0010 0011 0020 0011 0010 0021 0020 0021 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0020 0021 0020 0011 0010 09EE"
- delay: 60ms
icon: mdi:play
on_press:
data: "0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0020 0010 0010 0020 0010 09BC"
- delay: 60ms
on_press:
data: "0000 0072 0000 0021 0061 0021 0010 0011 0010 0011 0010 0021 0010 0021 0030 0021 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0020 0011 0010 0011 0010 0011 0010 0021 0010 0011 0020 0011 0010 0021 0020 0021 0010 0011 0010 0011 0010 0011 0010 0011 0020 0011 0010 0011 0010 0011 0010 0021 0010 09D2"
- delay: 60ms
on_press:
data: "0000 0072 0000 0021 0061 0021 0010 0011 0010 0011 0010 0021 0010 0021 0030 0021 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0020 0011 0010 0011 0010 0011 0010 0021 0010 0011 0020 0011 0010 0021 0020 0021 0010 0011 0010 0011 0010 0011 0010 0011 0020 0011 0010 0011 0010 0011 0010 0011 0010 09DE"
- delay: 60ms
on_press:
data: "0000 0072 0000 0021 0061 0021 0010 0011 0010 0011 0010 0021 0010 0021 0030 0021 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0020 0011 0010 0011 0010 0011 0010 0021 0010 0011 0020 0011 0010 0021 0020 0021 0010 0011 0010 0011 0010 0011 0020 0021 0010 0011 0010 0011 0010 0011 0010 0011 0010 09CD"
- delay: 60ms
on_press:
data: "0000 0072 0000 0020 0061 0021 0010 0011 0010 0011 0010 0021 0010 0021 0030 0021 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0020 0011 0010 0011 0010 0011 0010 0011 0010 0021 0020 0011 0010 0021 0020 0021 0010 0011 0010 0011 0010 0011 0020 0021 0010 0011 0010 0011 0010 0011 0020 09E3"
- delay: 60ms
name: Kodi Now Playing
icon: mdi:flip-to-back
on_press:
data: "0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0020 0010 0010 0020 0010 0010 0020 0010 0010 09DD"
- delay: 60ms
