I don’t think I’ve changed a much, other than adding a couple of small bits. Here’s my latest:
substitutions:
friendly_name: IRBlaster
host_name: irblaster
esphome:
friendly_name: $friendly_name
bk72xx:
board: cb3s # https://docs.libretiny.eu/boards/cb3s/
# bk72xx:
# board: generic-bk7231n-qfn32-tuya
logger: # Enable logging. https://esphome.io/components/logger.html
level: DEBUG # NONE, ERROR, WARN, INFO, DEBUG (Default), VERBOSE, VERY_VERBOSE
baud_rate: 0 # Stops logging over onboard UART
api: # Enable Home Assistant API.
encryption:
key: !secret api_encryption_key
ota:
password: !secret ota_password
safe_mode: True
wifi: # WiFi connection details. Without domain:, defaults to .local. https://esphome.io/components/wifi.html
ssid: !secret wifi_ssid
# power_save_mode: LIGHT # NONE, LIGHT, HIGH
fast_connect: true
ap: # Enable fallback hotspot (captive portal) in case wifi connection fails
ssid: "${friendly_name} Fallback"
password: !secret fallback_password
captive_portal:
- platform: wifi_signal # Reports the WiFi signal strength in dB. https://esphome.io/components/sensor/wifi_signal.html
name: "WiFi Signal dB" # Uncomment to show signal DB in HA
update_interval: 60s # Report signal every minute
entity_category: "diagnostic"
device_class: "signal_strength"
disabled_by_default: true # Shows entity in HA, but disabled by default
internal: true
- platform: copy # Reports the WiFi signal strength %
source_id: wifi_signal_db
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "%"
- platform: uptime
# update_interval: 10s
# internal: true # Uncomment to leave internal and not send to HA
text_sensor:
# Expose WiFi information as sensors.
- platform: wifi_info
ip_address:
icon: mdi:wifi
mac_address:
icon: mdi:wifi
# ssid:
# name: Wi-fi SSID
# icon: mdi:wifi
# bssid:
# name: Router MAC
# icon: mdi:wifi
- platform: version
icon: mdi:wrench-outline
switch: # Switches
- platform: factory_reset
name: Restart with Factory Default Settings
entity_category: diagnostic
light:
- platform: status_led # Used as a status LED during boot/errors, and status_light when running/OK. https://esphome.io/components/light/status_led
pin: P8
# name: Status LED # Uncomment to show in HA
icon: mdi:led-on
binary_sensor:
# Status
- platform: status
name: "API Status" # Button, https://esphome.io/components/binary_sensor/gpio
- platform: gpio
pin:
number: P6
inverted: true
mode:
input: true
pullup: true # Holds it high/off, otherwise it flutters on/off
icon: "mdi:button-pointer"
# internal: true # Hides button from HA
# disabled_by_default: true # Shows entity in HA, but disabled by default
on_press: # Switch LED on/off as a test
- light.turn_on: status_light
on_release:
- light.turn_off: status_light
# on_double_click:
# then:
# - light.toggle: status_light
# Sync time with Home Assistant
time:
- platform: homeassistant
# # Home Assistant sensor to store received remote command data
# text_sensor:
# - platform: template
# name: Learned Command
# icon: mdi:remote
# id: learned_command
remote_receiver:
pin:
number: P7
inverted: true
mode:
input: true
pullup: true
tolerance: 25
dump: all
# dump: pronto
# dump: raw
# dump: samsung
# on_samsung:
# - if: # If Samsung code is received
# condition:
# lambda: 'return id(remote_learn_switch).state;'
# then:
# - lambda: |-
# id(remote_learn_switch).publish_state(false);
# std::string log_output = "Samsung: Data = 0x" + esphome::format_hex((uint32_t)x.data) + ", nbits = " + esphome::to_string(x.nbits);
# id(learned_command).publish_state(log_output.c_str());
# - delay: 80ms
# - light.turn_on: status_light
# - delay: 500ms
# - light.turn_off: status_light
# on_sony: # If Sony code is received
# - if:
# condition:
# then:
# - lambda: |-
# std::string log_output = "Sony: Data = 0x" + esphome::format_hex(x.data) + ", nbits = " + esphome::to_string(x.nbits);
# - delay: 80ms
# - delay: 500ms
# switch:
# Home Assistant controlled switch - to enable "learning mode"
# name: Learn Command
# id: remote_learn_switch
# icon: mdi:remote
# optimistic: true
remote_transmitter: # https://esphome.io/components/remote_transmitter.html
pin: P26
carrier_duty_percent: 50%
button:
- platform: restart
- platform: safe_mode
name: "Restart (Safe Mode)"
# IR codes to send from HA:
# FAN, Raw
icon: mdi:fan
on_press:
- remote_transmitter.transmit_raw:
carrier_frequency: 38kHz
code: [1155, -438, 1250, -403, 437, -1250, 1291, -396, 1282, -406, 437, -1260, 428, -1250, 437, -1264, 434, -1240, 437, -1250, 1295, -393, 469, -7947, 1303, -406, 1291, -397, 468, -1219, 1281, -413, 1275, -406, 437, -1250, 441, -1250, 434, -1251, 437, -1263, 425, -1250, 1281, -410, 468, -7948, 1299, -406, 1282, -406, 447, -1240, 1250, -438, 1263, -424, 438, -1278, 409, -1254, 437, -1266, 418, -1250, 444, -1247, 1247, -438, 437, -7979, 1281, -428, 1250, -437, 438, -1263, 1237, -437, 1250, -438, 419, -1268, 407, -1281, 406, -1294, 425, -1250, 406, -1294, 1237, -438, 406]
- delay: 60ms
icon: mdi:fan-off
on_press:
code: [1164, -389, 1288, -399, 469, -1266, 1232, -414, 1275, -409, 441, -1274, 444, -1243, 437, -1267, 420, -1253, 434, -1267, 420, -1253, 1247, -7185, 1250, -441, 1246, -379, 472, -1274, 1266, -390, 1284, -403, 469, -1266, 421, -1253, 434, -1253, 437, -1246, 441, -1247, 439, -1264, 1240, -7165, 1271, -399, 1298, -390, 468, -1253, 1252, -417, 1265, -412, 462, -1250, 442, -1248, 435, -1253, 434, -1266, 421, -1256, 431, -1254, 1249, -7167, 1265, -444, 1243, -410, 481, -1233, 1287, -400, 1297, -390, 437, -1254, 434, -1266, 421, -1253, 434, -1249, 446, -1255, 440, -1240, 447]
- delay: 60ms
icon: mdi:fan-chevron-up
on_press:
code: [1188, -403, 1298, -389, 437, -1250, 1291, -396, 1283, -403, 438, -1259, 428, -1249, 1281, -406, 437, -1256, 431, -1249, 438, -1259, 427, -8011, 1267, -406, 1284, -406, 434, -1250, 1280, -407, 1294, -392, 438, -1249, 437, -1288, 1243, -437, 406, -1291, 396, -1281, 406, -1281, 409, -8006, 1268, -437, 1249, -438, 406, -1290, 1240, -437, 1253, -434, 406, -1280, 406, -1281, 1259, -428, 406, -1280, 406, -1291, 409, -1268, 406, -8016, 1288, -410, 1249, -438, 406, -1293, 1237, -437, 1250, -437, 406, -1291, 396, -1280, 1263, -424, 406, -1281, 437, -1250, 416, -1270, 438, -7994, 1252, -437, 1259, -428, 406, -1280, 1260, -427, 1250, -437, 437, -1260, 427, -1249, 406, -1281, 404, -1293, 427, -1250, 437, -1263, 393, -8010, 1267, -437, 1255, -438, 431, -1250, 1249, -534, 1166, -424, 406, -1281, 406, -1294, 424, -1249, 438, -1259, 396, -1281, 437, -1250, 409, -8007, 1267, -437, 1250, -437, 406, -1291, 1239, -438, 1252, -437, 406, -1278, 406, -1295, 399, -1283, 396, -1281, 406, -1291, 396, -1281, 409, -8105, 1176, -462, 1218, -469, 375, -1286, 1246, -470, 1217, -438, 406, -1292, 396, -1282, 406, -1295, 393, -1281, 406, -1282, 416, -1272, 406]
- delay: 60ms
# name: Fan Timer
# icon: mdi:fan-clock
# on_press:
# - remote_transmitter.transmit_raw:
# carrier_frequency: 38kHz
# code: [1174, -378, 1312, -371, 476, -1212, 1315, -372, 1334, -353, 468, -1253, 434, -1226, 461, -1219, 1315, -372, 472, -1225, 458, -1222, 465, -7984, 1315, -355, 1315, -372, 468, -1242, 1289, -378, 1309, -375, 482, -1205, 469, -1221, 466, -1242, 1292, -371, 469, -1222, 465, -1245, 445, -8004, 1272, -378, 1312, -371, 472, -1215, 1331, -356, 1316, -371, 469, -1242, 445, -1222, 465, -1218, 1305, -383, 472, -1215, 468, -1242, 445, -7959, 1323, -372, 1301, -386, 437, -1253, 1309, -378, 1278, -406, 472, -1184, 468, -1241, 446, -1222, 465, -1239, 449, -1221, 465, -1219, 523]
# - delay: 60ms
# name: Fan Mode
# icon: mdi:fan-auto
# on_press:
# code: [1151, -441, 1246, -409, 438, -1277, 1253, -434, 1269, -419, 406, -1284, 403, -1304, 383, -1284, 403, -1280, 1273, -414, 422, -1272, 399, -8015, 1284, -417, 1256, -431, 406, -1305, 1226, -444, 1243, -440, 406, -1278, 409, -1278, 406, -1303, 384, -1284, 1253, -431, 406, -1284, 403, -8014, 1264, -458, 1229, -441, 403, -1282, 1304, -383, 1317, -371, 407, -1305, 414, -1253, 404, -1284, 403, -1285, 1313, -372, 437, -1271, 417, -7994, 1293, -403, 1305, -383, 438, -1253, 1281, -426, 1266, -403, 435, -1250, 444, -1244, 437, -1254, 434, -1274, 1261, -403, 438, -1254, 434, -7994, 1305, -366, 1306, -376, 475, -1212, 1317, -371, 1335, -354, 468, -1223, 465, -1243, 445, -1222, 466, -1219, 1305, -383, 449, -1246, 431, -7987, 1285, -418, 1253, -434, 407, -1274, 1265, -434, 1247, -441, 406, -1247, 441, -1247, 438, -1272, 416, -1253, 1283, -433, 407, -1254, 434, -8018, 1265, -462, 1226, -441, 403, -1250, 1308, -411, 1254, -434, 375, -1305, 383, -1285, 403, -1285, 406, -1279, 410, -1278, 406, -1276, 412, -8037, 1251, -403, 1308, -380, 437, -1254, 1295, -409, 1310, -362, 437, -1298, 392, -1245, 438, -1255, 528, -1180, 413, -1254, 434, -1260, 428]
# - delay: 60ms
# Fish light, Raw
name: Fish light On/Off
icon: mdi:wall-sconce-flat-outline
on_press:
code: [9956, -4437, 680, -1594, 687, -538, 650, -531, 656, -531, 656, -532, 659, -528, 656, -1593, 688, -531, 688, -531, 656, -1593, 688, -1624, 688, -1597, 684, -1593, 688, -1611, 701, -500, 656, -1628, 684, -1593, 688, -531, 656, -531, 657, -1593, 691, -1590, 688, -531, 656, -535, 653, -531, 687, -500, 656, -1706, 607, -1593, 689, -533, 653, -531, 657, -1595, 689, -1591, 688, -1632, 681]
- delay: 60ms
name: Fish light 12:00
icon: mdi:update
on_press:
code: [9777, -4469, 646, -1704, 577, -594, 594, -597, 628, -556, 625, -562, 625, -563, 635, -1681, 590, -594, 625, -575, 612, -1656, 625, -1708, 621, -1643, 622, -1711, 601, -1657, 676, -511, 625, -1688, 625, -585, 602, -563, 625, -1656, 647, -1665, 625, -1679, 603, -593, 625, -563, 594, -600, 660, -1646, 625, -1682, 600, -593, 594, -594, 656, -545, 643, -1682, 630, -1651, 599, -1688, 687]
- delay: 60ms
# Samsung TV, Samsung
# icon: mdi:check
icon: mdi:keyboard-return
on_press:
- remote_transmitter.transmit_samsung:
data: 0xE0E016E9
- delay: 60ms
icon: mdi:power
on_press:
data: 0xE0E040BF
- delay: 60ms
# name: TV Source
# icon: mdi:television
# on_press:
# - remote_transmitter.transmit_samsung:
# data: 0xE0E0807F
# - delay: 60ms
icon: mdi:volume-mute
on_press:
data: 0xE0E0F00F
- delay: 60ms
icon: mdi:menu
on_press:
data: 0xE0E058A7
- delay: 60ms
icon: mdi:undo
on_press:
data: 0xE0E01AE5
- delay: 60ms
icon: mdi:arrow-up-bold-outline
on_press:
data: 0xE0E006F9
- delay: 60ms
icon: mdi:arrow-down-bold-outline
on_press:
data: 0xE0E08679
- delay: 60ms
icon: mdi:arrow-left-bold-outline
on_press:
data: 0xE0E0A659
- delay: 60ms
icon: mdi:arrow-right-bold-outline
on_press:
data: 0xE0E046B9
- delay: 60ms
icon: mdi:exit-to-app
on_press:
data: 0xE0E0B44B
- delay: 60ms
icon: mdi:tools
on_press:
data: 0xE0E0D22D
- delay: 60ms
icon: mdi:information-variant
on_press:
data: 0xE0E0F807
- delay: 60ms
# name: TV Vol+
# icon: mdi:volume-plus
# on_press:
# data: 0xE0E0E01F
# - delay: 60ms
# name: TV Vol-
# icon: mdi:volume-minus
# on_press:
# data: 0xE0E0D02F
# - delay: 60ms
# name: TV Channel+
# icon: mdi:chevron-up
# on_press:
# data: 0xE0E048B7
# - delay: 60ms
# name: TV Channel-
# icon: mdi:chevron-down
# on_press:
# data: 0xE0E008F7
# - delay: 60ms
# name: TV Guide
# icon: mdi:television-guide
# on_press:
# data: 0xE0E0F20D
# - delay: 60ms
# PC, Pronto
# yellow
icon: mdi:television-ambient-light
on_press:
- remote_transmitter.transmit_pronto:
data: "0000 0073 0000 0020 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 0020 0020 0010 0010 0010 0010 0020 0020 09DD"
- delay: 60ms
name: Kodi Clean Library
icon: mdi:kodi
on_press:
code: [2516, -921, 406, -468, 438, -437, 406, -937, 406, -906, 1315, -903, 406, -500, 406, -468, 406, -469, 406, -500, 406, -469, 406, -500, 405, -469, 406, -467, 408, -468, 438, -468, 844, -468, 437, -469, 406, -469, 406, -923, 388, -500, 407, -468, 409, -466, 437, -469, 843, -937, 406, -469, 406, -468, 844, -937, 437, -454, 858, -906, 406, -468, 406, -500, 406]
- delay: 60ms
# Guide
name: Kodi Refresh Library
icon: mdi:refresh
on_press:
data: "0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0020 0010 0010 0020 0010 09CD"
- delay: 60ms
icon: mdi:pause
on_press:
data: "0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0020 0010 0010 0010 0010 0010 09BD"
- delay: 60ms
icon: mdi:undo
on_press:
data: "0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 0010 0010 09CF"
- delay: 60ms
# icon: mdi:check
on_press:
data: "0000 0071 0000 0020 0061 0021 0010 0011 0010 0011 0010 0021 0010 0021 0030 0021 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0020 0011 0010 0011 0010 0011 0010 0021 0010 0011 0020 0011 0010 0021 0020 0021 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0020 0021 0020 0011 0010 09EE"
- delay: 60ms
icon: mdi:play
on_press:
data: "0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0020 0010 0010 0020 0010 09BC"
- delay: 60ms
on_press:
data: "0000 0072 0000 0021 0061 0021 0010 0011 0010 0011 0010 0021 0010 0021 0030 0021 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0020 0011 0010 0011 0010 0011 0010 0021 0010 0011 0020 0011 0010 0021 0020 0021 0010 0011 0010 0011 0010 0011 0010 0011 0020 0011 0010 0011 0010 0011 0010 0021 0010 09D2"
- delay: 60ms
on_press:
data: "0000 0072 0000 0021 0061 0021 0010 0011 0010 0011 0010 0021 0010 0021 0030 0021 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0020 0011 0010 0011 0010 0011 0010 0021 0010 0011 0020 0011 0010 0021 0020 0021 0010 0011 0010 0011 0010 0011 0010 0011 0020 0011 0010 0011 0010 0011 0010 0011 0010 09DE"
- delay: 60ms
on_press:
data: "0000 0072 0000 0021 0061 0021 0010 0011 0010 0011 0010 0021 0010 0021 0030 0021 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0020 0011 0010 0011 0010 0011 0010 0021 0010 0011 0020 0011 0010 0021 0020 0021 0010 0011 0010 0011 0010 0011 0020 0021 0010 0011 0010 0011 0010 0011 0010 0011 0010 09CD"
- delay: 60ms
on_press:
data: "0000 0072 0000 0020 0061 0021 0010 0011 0010 0011 0010 0021 0010 0021 0030 0021 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0010 0011 0020 0011 0010 0011 0010 0011 0010 0011 0010 0021 0020 0011 0010 0021 0020 0021 0010 0011 0010 0011 0010 0011 0020 0021 0010 0011 0010 0011 0010 0011 0020 09E3"
- delay: 60ms
name: Kodi Now Playing
icon: mdi:flip-to-back
on_press:
data: "0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0020 0010 0010 0020 0010 0010 0020 0010 0010 09DD"
- delay: 60ms
