What's the best way to get the state for a specific entity of a device?
I’m writing a script and have added a device selector field and wish to get the state of a specific entity on the selected device.
More specifically, I have several Ulanzi TC001 clock’s around the house flashed with AWTRIX Light. I’m writing a script to allow me to construct a messages to be displayed on a clocks via the mqtt.publish service with a topic of <device_topic>/notifiy. The device_topic for each device is available as an entity on the device (i.e. sensor.living_room_device_topic, sensor.kitchen_device_topc, etc.). In my script I have a selector for a device (filtered to only show the clocks) and would like to extract the MQTT device topic from the selected device.
I’ve managed to come up with the following that works.
alias: Awtrix Send Notification
description: Display a notification on an AWTRIX powered device
icon: mdi:alphabetical-variant
mode: parallel
fields:
  device_id:
    description: Device on which to show the notification
    required: true
    selector:
      device:
        filter:
          - integration: mqtt
            manufacturer: Blueforcer
            model: AWTRIX Light
  # ADDITIONAL FIELDS OMITTED FOR BREVITY
sequence:
  - service: mqtt.publish
      topic: "{{ states(device_entities(device_id) | select('contains', 'device_topic') | first) }}/notify"
      payload_template: # OMITTED FOR BREVITY
Is there a better way of retrieving the device topic?
Hi, I was searching for the exact same thing. Did you find a definitive answer ?
For now I’m using your current solution.
Is there a reason you’re using a device selector? Just use an entity selector and filter it to only allow specific domains and devices.
I modified a blueprint that used device id and did not want to rewrite the whole thing.
