that would be brightness-5 and the accompanying one is brightness-7 or set them by using the device_class light
if you know what you’re looking for
That’s very true! I looked at that icon and thought “I’ve seen that!” and then proceeded to search for “sun” and “light” and … yeah, it’s a slow process.
Thanks all! And yes… I always use:
https://cdn.rawgit.com/james-fry/home-assistant-mdi/efd95d7a/home-assistant-mdi.html
But mdi:brightness-5 it is!
FWIW, I believe in version 0.115 Home Assistant will be using a newer version of Material Design icons than what is shown in the james-fry link.
For example, mdi:cog is the new name for what is known in older versions as mdi:settings
The only reason I know this is because Home Assistant 0.114 warned me (in the log) that the mdi:settings icon I was using would become unavailable.
Ok, yes I had that for mdi:hotel which becomes mdi:bed.
I presume that is in 115 it will be updated it will also be correctly documented (somewhere)…
It’ll probably be one of the hundred or so changes listed in the blog heading that says “Click to see all changes!”
