Ssl/fullchain.pem doesn’t work. The example in the docs points to a letsencrypt folder path and I’m using duckdns with le. So my .pem files are in the ssl folder located in the config folder
Edit using hadashboard
I’m using the Appdeamon add on within hass.io and would also love to be able to encrypt my HAdashboard. Don’t love the fact that there is no SSL option if you are using the addon.
encryption inside a home network is useless unless you think there are people in your own network trying to hack things.
to use dashboard and home assistant outside your own network you need
