I am trying to flash Tasmota into a Kuled Switch. Actually, my second one as the first flashed fine.
After flashing, I get the state from Tasmota, then I try to give it my SSID and MQTT credentials, and it appears to accept them,
then it reboots- as expected, but then it dies. Reboot does nothing including no status.
Any clue what may be happening?
(BTW- after the fifth flash, everything worked).
The following is from a serial terminal program (Termite).
15:13:43 MQT: tele/sonoff/STATE = {"Time":"2018-10-31T15:13:43","Uptime":"0T00:00:17","Vcc":4.094,"POWER":"ON","Wifi":{"AP":1,"SSId":"xxywinnet","RSSI":52,"APMac":"18:1B:EB:7B:0D:E2"}}
Backlog SSID1 xxywinnyt; Password1 806194xxxx8; MqttHost 192.168.1.111
15:13:53 CMD: Backlog SSID1 xxywinnyt; Password1 806194xxxx8; MqttHost 192.168.1.111
15:13:53 MQT: stat/sonoff/RESULT = {"SSId1":"xxywinnyt"}
15:13:53 MQT: stat/sonoff/RESULT = {"Password1":"806194xxxx8"}
15:13:53 MQT: stat/sonoff/RESULT = {"MqttHost":"192.168.1.111"}
15:13:55 APP: Restarting
ets Jan 8 2013,rst cause:1, boot mode:(1,7)
ets Jan 8 2013,rst cause:4, boot mode:(1,7)
wdt reset
