I’m building my system from scratch after I updated from 0.114.3 to whatever is the latest version today
This was working fine, but apparently something has changed, and causes home assistant to be slow on manual restart and also randomly restarts sometimes which I cannot accept
I’ve already setup my lights, switches and binary sensors, and it restarts in a few minutes and I only get 3 or 4 warnings, the like of “platform xxx is taking more than 10 secnds to setup”, which I understand to be fine
However, when I add the following, everything is so much slower
this is what I see when it restarts quickly (5 minutes)
[17:23:53] INFO: Using udev information from host
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
2021-04-27 17:24:28 WARNING (MainThread) [homeassistant.setup] Setup of utility_meter is taking over 10 seconds.
2021-04-27 17:24:37 WARNING (MainThread) [homeassistant.components.switch] Setup of switch platform mqtt is taking over 10 seconds.
2021-04-27 17:24:37 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform filter is taking over 10 seconds.
2021-04-27 17:26:33 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform mobile_app is taking over 10 seconds.
2021-04-27 17:26:33 WARNING (MainThread) [homeassistant.setup] Setup of default_config is taking over 10 seconds.
2021-04-27 17:26:33 WARNING (MainThread) [homeassistant.components.device_tracker] Setup of device_tracker platform mobile_app is taking over 10 seconds.
2021-04-27 17:26:33 WARNING (MainThread) [homeassistant.components.weather] Setup of weather platform met is taking over 10 seconds.
2021-04-27 17:28:49 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: utility_meter, default_config
2021-04-27 17:28:49 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating workday binary_sensor took longer than the scheduled update interval 0:00:30
2021-04-27 17:28:49 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ping binary_sensor took longer than the scheduled update interval 0:00:30
2021-04-27 17:29:01 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 19)
2021-04-27 17:29:01 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 20)
2021-04-27 17:29:01 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 21)
2021-04-27 17:29:01 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 22)
2021-04-27 17:29:01 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 23)
2021-04-27 17:29:01 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 24)
2021-04-27 17:29:01 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 25)
2021-04-27 17:29:01 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 26)
2021-04-27 17:29:01 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 27)
2021-04-27 17:29:01 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 28)
2021-04-27 17:29:01 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 29)
2021-04-27 17:29:01 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 30)
2021-04-27 17:29:01 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 31)
2021-04-27 17:29:01 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 32)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 33)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 34)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 35)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 36)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 37)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 38)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 39)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 40)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 41)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 42)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 43)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 44)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 45)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 46)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 47)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 48)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 49)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 50)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 51)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 52)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 53)
2021-04-27 17:29:02 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 54)
2021-04-27 17:29:06 WARNING (MainThread) [homeassistant.components.automation.input_amp_limit] input amp limit: Already running
2021-04-27 17:29:15 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 55)
2021-04-27 17:29:16 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 56)
2021-04-27 17:29:16 WARNING (MainThread) [homeassistant.components.mqtt] No ACK from MQTT server in 10 seconds (mid: 57)
Hi, I have your same configuration but no problem for me.
I landed to your post after a google search. My problem is that when the prism/1/mode is in “Pausa causata da autolimit” it stays that way, even if after the power from solar is enough to charge the car.
