What's wrong with my Espome yaml code it have breaken 03 Sonoff mini already flashed with esphome
What’s wrong with my Espome yaml code that broken 03 of my Sonoff mini already flashed with esphome, i was only updating my code
when the upload finishes the three (03) Sonoff Mini r2 stopped and gives a positif ping sometimes but everything doesnt work including the phisical s1,s2 button and it doesn’t apear with its address 192.168.8.100
i have tried reflashing them using UART but they didn’t connect to the esphomeflasher tool under linux
i think because i was using the Rx pin as an ordinary pin like the following lines
logger:
  level: DEBUG
  baud_rate: 0
SOLVED (when flashing new nodes) without the next code lines, but 03 Sonoff mini r2 still dammaged
  js_include: "./v2/www.js"
  css_include: "./v2/www.css"
  version: 2
my full code is the following:
substitutions:
  device_name: "hooming-kpa-01"
esphome:
  friendly_name: kpa-01
  # Automatically add the mac address to the name
  # so you can use a single firmware for all devices
  name_add_mac_suffix: true
esp8266:
  board: esp8285
# Enable Home Assistant API
api:
  encryption:
    key: "fsvB60LOnM7UpzgMqkXNgPnrie+TecOFHVZYse9QZ/s="
ota:
  password: "2acf3099eaeed28119af118576835839"
captive_portal:
wifi:
  # esphome Fast connect can only be used with one network!.
  # fast_connect: true
  # reboot_timeout: 60s
  use_address: 192.168.8.65
  networks:
    - ssid: !secret wifi_ssid
      manual_ip:
        gateway: 192.168.8.1
        subnet: 255.255.255.0
        static_ip: 192.168.8.100
    - ssid: BROADBAND
      manual_ip:
        gateway: 192.168.1.1
        static_ip: 192.168.1.100
  ap:
    ssid: "${device_name}"
    password: "IvIwT3MH2axb"
# Disable Logger (TO USE RX as A regular Pin)
logger:
  level: DEBUG
  baud_rate: 0
# Enable Web server
web_server:
  port: 80
  version: 2
# Global to store the on/off state of the chime
globals:
  - id: turned_on_manually
    type: bool
    restore_value: true
    initial_value: 'false'
  - id: turned_off_manually
    type: bool
    restore_value: true
  - id: till_turn_off_manually
    type: bool
    restore_value: true
# Extra sensor to keep track of plug uptime
  - platform: uptime
    name: ${device_name} وقت التشغيل
    filters:
      - lambda: return x / 3600;
    unit_of_measurement: "hours"
    accuracy_decimals: 2
# Extra sensor for WiFi signal
  - platform: wifi_signal
    name: ${device_name} جودة شبكة الواي فاي
    update_interval: 60s
status_led:
  pin:
    number: GPIO13
    inverted: true
output:
  - platform: gpio
    pin: GPIO12
light:
  - platform: binary
    output: relay_1
    on_turn_off:
      then:
        - switch.turn_off:
    on_turn_on:
      then:
        - switch.turn_off:
# Example configuration entry
number:
    optimistic: true
    min_value: 0
    max_value: 30
    step: 1
switch:
    name:  " ON تم تشغيله يدويا"
    restore_state: false
    turn_on_action:
      - globals.set:
          value: 'true'
    turn_off_action:
      - globals.set:
          value: 'false'
    lambda: |-
      return id(turned_on_manually);
    name: ' OFF تم إطفاءه يدويا'
    turn_on_action:
      - globals.set:
          value: 'true'
    turn_off_action:
      - globals.set:
          value: 'false'
    lambda: |-
      return id(turned_off_manually);
    turn_on_action:
      - globals.set:
          value: 'true'
    turn_off_action:
      - globals.set:
          value: 'false'
    lambda: |-
      return id(till_turn_off_manually);
    name: 'api light on off'
    turn_on_action:
            - light.turn_on:
            - logger.log:
                level: DEBUG
                format: 'ON api_light_on_off'
    turn_off_action:
      - if:
          condition:
            - for:
                time: 8sec
                condition:
                  binary_sensor.is_off: kpa_motion_sensor
            # - switch.is_off:  iamaway
          then:
            - light.turn_off:
            - logger.log:
                level: DEBUG
                format: 'OFF api_light_on_off'
  # - platform: template
  #   name: 'i am away'
  #   id: iamaway
  #   restore_state: true
  #   optimistic: True
binary_sensor:
    lambda: |-
      if (id(motions_counter).state > 0){
        return true;}
        else  {
        return false;
  - platform: gpio
    pin: GPIO00
    internal: true
    filters:
      - invert:
      - delayed_off: 10ms
    on_press:
      - light.toggle:
  - platform: gpio
    pin:
      number: GPIO03
      # mode: INPUT_PULLUP
      # inverted: True
    name: "حساس الحركة  "
    device_class: motion
    on_press:
      if:
        condition:
          - for:
              time: 5sec
              condition:
                light.is_off: kpa_light
        then:
          - number.increment:
              cycle: false
          - if:
              condition:
                - binary_sensor.is_on: enough_motion
              then:
                - light.turn_on:
    # on_release:
    #   if:
    #     condition:
    #       for:
    #         time: 1min
    #         condition:
    #           binary_sensor.is_off: kpa_light_wassat-rewaq-motion_sensor
    #     then:
    #       - light.turn_off:
    #           id: kpa_light
# time:
#   - platform: sntp
  - platform: gpio
    # name: ${device_name}_Lights
    pin: GPIO04
    on_press:
      then:
#        - switch.turn_on:
        - light.toggle:
        - delay: 1s
        - if:
            condition:
              light.is_on: kpa_light
            then:
              - switch.turn_on:
              - switch.turn_off:
        - if:
            condition:
            then:
              - switch.turn_on:
              - switch.turn_off:
    on_release:
      then:
#        - switch.turn_off:
        - light.toggle:
        - delay: 1s
        - if:
            condition:
            then:
              - switch.turn_on:
              - switch.turn_off:
        - if:
            condition:
            then:
              - switch.turn_on:
              - switch.turn_off:
#   - platform: gpio
#     pin:
#       number: GPIO03
#       inverted: True
#     name: "PULLUP_Button"
#     id: switch_2
#     on_press:
#       then:
# #        - switch.turn_on:
#         - light.toggle:
#             id: kpa_light
#     on_release:
#       then:
# #        - switch.turn_off:
#         - light.toggle:
#             id: kpa_light
sun:
  latitude: 36.5431918°
  longitude: 3.4397346°
time:
  - platform: homeassistant
    on_time:
      # Every 1 minute
      # - minutes: '*'
      #   seconds: /10
      #   then:
      #     - number.decrement:
      #         id: motions_counter
      #         cycle: false
      #     - if:
      #         condition:
      #           - binary_sensor.is_off: enough_motion
      #           - switch.is_off: turned_on_manually_action
      #         then:
      #           - light.turn_off:
      #               id: kpa_light
      #               id: turned_off_manually_action
      - minutes: 15
        then:
          - if:
              condition:
                - switch.is_on: turned_on_manually_action
                - for:
                    time: 15min
                    condition:
              then:
                - light.turn_off:
                - switch.turn_off:
      - seconds: /1
        minutes: '*'
        then:
        - if:
            condition:
              - for:
                  time: 1.7sec
                  condition:
                    binary_sensor.is_on: kpa_motion_sensor
              # - sun.is_below_horizon:
            then:
              - light.turn_on:
              - switch.turn_off:
If we check the docs we find this information on the very top of the site :page_facing_up:
Web Server Component
The web_server component creates a simple web server on the node that can be accessed through any browser and a simple REST API. Please note that enabling this component will take up a lot of memory and may decrease stability, especially on ESP8266
Including js and css locally obviously makes things even worse.
I doubt that very much - probably just soft bricked.
The later doesn’t matter if you set the device into flash mode as the user code (esphome) will then not be loaded at all.
