What's wrong with this sensor
Hello there,
I just found out one of battery on motion sensor pretty low and was thinking about a sensor which could give it to me. Luckily I found a video about it so I just copied the code from there as it is doing what I actually need.
Here is the code in templates.yaml
- sensor:
    - name: "Vyměnit baterku"
      unique_id: xxxxxxx...
      icon: mdi:battery-low
      state: >
        {% set threshold = states('input_number.battery_threshold') | int %}
        {%- set ns = namespace(sensors=[]) -%}
        {%- for state in states.sensor
          | selectattr('attributes.device_class', 'defined')
          | selectattr('attributes.state_class', 'defined')
          | selectattr('attributes.unit_of_measurement', 'defined')
          | selectattr('attributes.device_class', '==', 'battery')
          | selectattr('attributes.state_class', '==', 'measurement')
          | selectattr('attributes.unit_of_measurement', '==', '%')
          | selectattr('state', 'is_number') -%}
          {%- if state.state | int <= threshold -%}
            {% set ns.sensors = ns.sensors + [dict(name = state.name | replace(' battery', '') | replace(' Battery', ''), state = state.state | int)] %}
          {% endif %}
        {% endfor %}
        {%- set batt = ns.sensors | sort(attribute='state') -%}
        {%- set ns = namespace(batt='') -%}
        {%- for state in batt -%}
          {% set ns.batt = ns.batt + (state.name ~ ' (' ~ state.state ~ '%)' ~ "\n") %}
        {% endfor %}
        {% if ns.batt | count > 0 %}
          {{ ns.batt | truncate(255, true, '...') }}
        {% else %}
          {{ 'unavailable' }}
        {% endif %}
There’s no error in editor, yaml validator says it’s ok, still when I checking it in developer there is a error notification which says:
Logger: homeassistant.config
Source: config.py:357
First occurred: 19:47:18 (8 occurrences)
Last logged: 19:59:54
Invalid config for ‘template’ at templates.yaml, line 45: invalid template (TemplateSyntaxError: expected token ‘end of statement block’, got ‘ns’) for dictionary value ‘sensor->0->state’, got '{% set threshold = states('input_number.battery_threshold') | int %} {%- set ns = namespace (sensors=) -%} {% for state in states.sensor | selectattr('attributes.device_class', 'defined') | selectattr('attributes.state_class', 'defined') | selectattr('attributes.device_class', '==' 'battery') | selectattr('attributes.state_class', '==', 'measurement') | selectattr('state', 'is_number') -%}\n {% if state.state | int <= threshold -%}\n {% set ns.sensors ns.senso…
Invalid config for ‘template’ at templates.yaml, line 45: invalid template (TemplateSyntaxError: expected token ‘end of statement block’, got ‘ns’) for dictionary value ‘sensor->0->state’, got '{% set threshold = states('input_number.battery_threshold') | int %} {%- set ns = namespace (sensors=) -%} {%- for state in states.sensor\n | selectattr('attributes.device_class', 'defined')\n | selectattr('attributes.state_class', 'defined')\n | selectattr('attributes.device_class', '==' 'battery')\n | selectattr('attributes.state_class', '==', 'measurement')\n | selectattr('state', 'is_number') -%}\n {%- if state.state | int <= threshold -%}\n {% set ns…
Invalid config for ‘template’ at templates.yaml, line 45: invalid template (TemplateSyntaxError: expected token ‘end of statement block’, got ‘ns’) for dictionary value ‘sensor->0->state’, got "{% set threshold = states(‘input_number.battery_threshold’) | int %} {%- set ns = namespace (sensors=) -%} {%- for state in states.sensor\n | selectattr(‘attributes.device_class’, ‘defined’)\n | selectattr(‘attributes.state_class’, ‘defined’)\n | selectattr(‘attributes.device_class’, ‘==’ ‘battery’)\n | selectattr(‘attributes.state_class’, ‘==’, ‘measurement’)\n | selectattr(‘state’, ‘is_number’) -%}\n {%- if state.state | int <= threshold -%}\n {% set ns.sensors ns.sensors + [dic…
Any idea what could be wrong?
Missing an equal sign.
Do a find on ‘ns.sensors ns.sensors’
Oops, that is a typo after I was checking it with image to text feature. But not really the solution, the result is still the same :confused:
I suspect you have another syntax error.
Is it really the same result? Or is the error different?
Something other than
You are missing a comma on one of your select_attributes and on the same line where you missed an equal sign, there is something wrong with the dict.
ETA: the dict is also missing an equal sign.
You either copied something that did not work or copied it wrong.
First, I typed it from a screen later after let’s say quite a few checks I went for some image to text solution and that did made horrible things obviously. Anyway, the original error said something different than the one posted so there was something I typed wrong for sure but did not see. With your hint I made it correct finally. Thank you for your time and help, @jeffcrum
For others - if needed - corrected and functional is the edited original code in a topic. And of course my source: https://www.youtube.com/watch?v=VgV_ExVeSfE
