Whats wrong?
Someone could help me?
I can’t figure out what is wrong:
If inside automation and tested in the developer with the same values,…
Remove the comment, it isn’t one. It is extra text. In jinja, comments are {# … #}
Thank you very much!! :slight_smile: :slight_smile:
Please take the time to mark the solution as the answer, you do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
