What's your favorite theme? (And why is it not Noctis?)
@bergasha how did you remove the transparent-like banner that normally shows with the State (home, away)? If show state: true then it appears to have a bar across the bottom that I’m not a fan on
Sharing my Blackcurrant theme which is based on Noctis but with a dark purple/pink palette. It’s not published on HACS yet so would need to add the repo manually to HACS to use it.
Bergasha
Would it be possible to see your code and how you did a wonderful theme. I am new to this and this is a wonderful theme. would like to use it at home. of course changing the pics and names. lol
Hey Hey, all my code is in a few posts from the top :ok_hand:
Guys I have an issue with Kibibit where I have white text on a white background in the edit dialog boxes below
Can some please point me in the right direction, either make the backgrounds darker or changing the text without changing the whole theme text colour which i seem to be able to do by modifying the primary text colour in the kibibit yaml file.
Thanks guys
