No no, they are only connected to the MCU via I2C, but their job is to expose 16 additional GPIOs, just like the ones on the MCU itself. You can connect up to 8 of these chips to a single ESP, which gives you an additional 128 GPIOs. Each chip is only 1 to 2 $/€.
Ah I see. Good to know. Thanks.
Got any you recommend? Preferably on Ali.
There are a bunch of different versions with different packages or even with SPI instead of I2C. I personally prefer the I2C DIP version (MCP23017-E/SP) because it is easy to solder. Best ask ChatGPT about the existing versions. Just (try to) make sure that you buy an original from Microchip, not from a Chinese copy cat.
There is also a concurrent chip design called PCF8575 from NXP that is also a good product with just some restrictions (again ask the AI).
I absolutely agree, and I can only add that I’ve started my journey from:
- NodeMCU ESP8266 (Wemos D1 Mini clone)
- NodeMCU ESP-32 ESP-WROOM-32S CP2102
Without any issues, just reading the docs and adding configs, I managed to smartify my inverter and create a simple CO2 sensor with Wemos.
However, I ordered C6 as the next board to play with all fancy things like Zigbee, and most of the time, I’m busy seeking docs and configs to make this board useful.
Finally:
I have a working CO2 sensor at the C6 board after this:
I only managed to create a blinking LED after this:
The most essential things are working fine. I could recreate a simple interlock relay logically and physically, control external LED with GPIO, etc.
But I would not recommend this journey to the past version of myself if I could.
This is quickly becoming one of my favorite boards. S3, POE, easy camera interface and works with raspberry pi cameras. USB C for optional power and flashing and an sdcard slot. Great for BT applications because WiFi isn’t used. If you look at the S3 lillygo version, which has POE but it costs the same as the board (or very close), has no USB C but that’s a non issue if you have a serial adapter but without POE you have to run cables to the board to power it.
While not getting to off topic it appears you can use the P4 now although I’m not an expert in PR’s. I wish I had snagged a wave share esp32-p4 with the POE shield but they are all out of stock and the full kits with touchscreen and camera are 80+ on AliExpress. Waveshare with POE hat is 25 with C6 for WiFi/BT… Pretty sure you need to run the dev version of ESPHome builder also. More of an FYI than to start a discussion but if I’m reading the PR wrong please correct me. If anyone has.a P4 to test any results would be appreciated.
Amazing find
Thanks for sharing!
Was wondering if you could post a simple yaml for a BT Proxy (as a starting point) for the board you recommended please?
I found some step files for 3D Printing a case for it and it is a decent price with decent options (seems to be a Waveshare or Waveshare clone actually)?
Thanks a lot!
Replying to myself.
Found @ginandbacon’s post with the yaml for the board he referenced (from Aliexpress) here.
It seems to be a WavShare or WavShare clone.
[EDIT]
Providing my simple yaml for this board, for reference / to assist others.
Only used as an Ethernet Based BT Proxy at this point. Not for use with Wifi.
substitutions: # name substitutions ref Digiblur https://digiblur.com/wiki/ha/esphome-bluetooth-proxy-esp32c3/
display_name: esp32s3poebtproxymb
friendly_name: ESP32S3PoEBTProxyMB
esphome:
friendly_name: ${friendly_name}
min_version: 2024.11.0
name_add_mac_suffix: false
# Optional Manual IP in wifi section
# manual_ip:
# static_ip: 192.168.53.xxx
# gateway: !secret gateway
# subnet: !secret subnet
ethernet: # For S3
type: W5500
mosi_pin: GPIO11
miso_pin: GPIO12
clk_pin: GPIO13
cs_pin: GPIO14
reset_pin: GPIO9
interrupt_pin: GPIO10
clock_speed: 25MHz
esp32:
variant: ESP32S3
board: esp32-s3-devkitc-1
flash_size: 16MB
framework:
type: esp-idf # This is important: the default "arduino" framework does not perform well.
sdkconfig_options:
CONFIG_BT_BLE_42_FEATURES_SUPPORTED: y # BLE 4.2 is supported by ALL ESP32 boards that have bluetooth, the original and derivatives.
CONFIG_BT_BLE_50_FEATURES_SUPPORTED: y # Also enable this on any derivative boards (S2, C3 etc) but not the original ESP32.
CONFIG_ESP_TASK_WDT: y
CONFIG_ESP_TASK_WDT_TIMEOUT_S: "10" # Extend the watchdog timeout, so the device reboots if the device appears locked up for over 10 seconds.
psram: # For S3
mode: octal
speed: 80MHz
switch: # For S3
- platform: gpio
pin: GPIO8
restore_mode: ALWAYS_OFF
setup_priority: 800
logger: # Enable logging
level: DEBUG # Debug=Default; use Verbose if error checking
# baud_rate: 0 # 0 Enables logging, but disables serial-port logging to free CPU and memory
ota: # Allow Over-The-Air updates
- platform: esphome
# password: !secret ota_password
api: # Enable Home Assistant API; MUST check option under ESPHome Configure!
encryption:
key: !secret encryption_key
# Requires wifi
# captive_portal:
esp32_ble_tracker:
scan_parameters: # Bermuda suggests 280/320 or 920/1000 to allow offset BT/Wifi
interval: 320ms # default 1100ms - Bermuda's defaults but also suggests 1000/900
window: 300ms # default 1100ms
continuous: true # Unlike Wifi Devices there is no control in the `api` block's automation, so for PoE makes this true
active: true # defaults to true - selecting false saves power but may not work - Bermuda also says select true
bluetooth_proxy:
active: true # Optional, defaults to false - true allows outbound connections from HA to devices.
button:
- platform: restart
entity_category: config
- platform: factory_reset
- platform: safe_mode
name: Safe Mode Boot
- platform: uptime
# The uptime sensor is extremely helpful to know if your device is rebooting
# when it shouldn't be. This might indicate your interval-to-window timing is
# too tight, and the window needs to be reduced.
update_interval: 60s
# time:
# - platform: homeassistant
# id: homeassistant_time
My bad, been a while since I been on here. Here is my full configuration, found an OV2060 camera from an old lilly flag device I wasn’t using. Actually pretty good frame rate but at lower resolutions.
I can’t wait for the P4 to be added, I got a dev kit, even though I died really need it but you can use a camera and it handles up to 1080p24fps using h264. It has a 7" screen and I can view video from the camera and it looks better than any S3 camera I’ve tried and that’s without a display. Saw a video on YouTube, apparently someone got Quake running on one. I guess Doom is to easy now? Around the seven minute mark
Uptime, IP and temperature are good sensors, not really sure what heap size is although I’m pretty sure it has to do with RAM.
substitutions:
friendly_name: ws_poe_s3
device_sampling_time: 90s
esphome:
on_boot:
priority: 700
then:
- switch.turn_off: relay1
- lambda: |-
delay(1200);
#includes:
# - idfWifi.h
# - idfWifi.c
esp32:
framework:
type: esp-idf
version: recommended
sdkconfig_options:
CONFIG_ESP32_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32_DATA_CACHE_64KB: "y"
CONFIG_ESP32_DATA_CACHE_LINE_64B: "y"
CONFIG_ESP32_INSTRUCTION_CACHE_32KB: 'Y'
flash_size: 16MB
psram:
mode: octal
speed: 80MHz
switch:
- platform: gpio
pin: GPIO8
setup_priority: 800
esp32_camera:
setup_priority: 200
external_clock:
pin: GPIO3
frequency: 20MHz
i2c_pins:
sda: GPIO48
scl: GPIO47
data_pins: [GPIO41, GPIO45, GPIO46, GPIO42, GPIO40, GPIO38, GPIO15, GPIO18]
vsync_pin: GPIO1
href_pin: GPIO2
pixel_clock_pin: GPIO39
max_framerate: 60 fps
idle_framerate: 0.01 fps
resolution: 640x480
jpeg_quality: 10
frame_buffer_count: 2
aec2: true
aec_mode: AUTO
# Enable logging
logger:
debug:
update_interval: ${device_sampling_time}
api:
encryption:
key: "Georgecarlin"
ota:
- platform: esphome
password: "dog"
#wifi:
# ssid: !secret wifi_ssid
# password: !cat
ethernet:
type: W5500
mosi_pin: GPIO11
miso_pin: GPIO12
clk_pin: GPIO13
cs_pin: GPIO14
reset_pin: GPIO9
clock_speed: 25MHz
time:
button:
- platform: restart
# ESP32 internal sensors
# Temperature
- platform: internal_temperature
name: Internal Temperature
- platform: debug
free:
block:
name: Heap max block
loop_time:
name: Heap free (%)
unit_of_measurement: '%'
accuracy_decimals: 2
icon: mdi:percent
entity_category: diagnostic
# 524288 B (SRAM total)
# 327680 B (DRAM usable)
lambda: return ( id(${friendly_name}_heap_free).state * 100 / 327680 );
name: Heap max block (%)
icon: mdi:percent
lambda: return ( id(${friendly_name}_heap_max_block).state * 100 / 327680 );
- platform: uptime
internal: true
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(${friendly_name}_uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
# Custom Text sensors
text_sensor:
- platform: ethernet_info
ip_address:
name: Uptime Human Readable
icon: mdi:clock-start
# include commented out files and copy locally for the below to work
# - platform: template
# id: wifi_channel
# name: "Net WiFi Channel"
# lambda: |-
# static char str[3]; // two digits (or -1) plus NULL
# sprintf(str, "%2d", idfWifiGetChannelNum());
# return (std::string) str;
#web_server:
# port: 80
# version: 2
# include_internal: true
# ota: false
#ap:
# ssid: "Ws-Poe-S3 Fallback Hotspot"
# password: "AB6J9ECa7R0F"
#captive_portal:
Cheers thank you, much appreciated!
Hey! How did you find the usable DRAM for your ESP32? The size is discussed here, but certain factors play into it. Is there a way to ask ESPHome?
Which board are you suggesting to buy in 2025?
I need something that works well with mqtt tls (and autodiscovery in HA) + ble_tracking + at least another UART component and i had some heap memory issue with an esp32doit-devkit.
I need something that is purchasable with no huge shipping costs from Italy (aliexpress?). Welded pins would be better.
Thanks!
