I am trying to use the integration of WhatsApp. The Whatsapp services of this integration is available and its services can be used (*).
However I notice some errors in Visual Studio Code and I was wondering if I could ignore these because the warnings are incorrect? I know of similar problems.
file: init.py :
- Import “homeassistant.core” could not be resolved
- Import “homeassistant.helpers.typing” could not be resolved
showing one:
"resource": "/opt/ha_test/config/custom_components/whatsapp/__init__.py",
"owner": "_generated_diagnostic_collection_name_#4",
"code": {
"value": "reportMissingImports",
"target": {
"$mid": 1,
"path": "/microsoft/pyright/blob/main/docs/configuration.md",
"scheme": "https",
"authority": "github.com",
"fragment": "reportMissingImports"
"severity": 4,
"message": "Import \"homeassistant.helpers.typing\" could not be resolved",
"source": "Pylance",
"startLineNumber": 8,
"startColumn": 6,
"endLineNumber": 8,
"endColumn": 34
file: whatsapp.py - Import “url_normalize” could not be resolved
"resource": "/opt/ha_test/config/custom_components/whatsapp/whatsapp.py",
"code": {
"target": {
"$mid": 1,
"scheme": "https",
"severity": 4,
"message": "Import \"url_normalize\" could not be resolved",
"startLineNumber": 2,
"startColumn": 6,
"endLineNumber": 2,
"endColumn": 19
I can not use the addon itself because my Homeassistant is installed in Docker.
(*) If someone knows the correct syntax to fill in each Whatsapp services that will be most welcome too.
(I realize that I still need to find out how to interact with the Dockered “whatsapp-api”)
