Hi Guys,
I’m trying for a while now to get remote access via DuckDNS to my hassio running on a Odroid C2.
When I configure the http in the configuration.yaml, I lose connection to the dashboard in any way, the remedy is to outcomment the HTTP in the config via Samba and then reboot Hassio to get local access again.
The logging for Hassio doesn’t give an error at all.
I port forwarded 443 External to 8123 Internal to the IP address of the Hassio.
Online port checker tells me that the 443 port is open when configured.
Configuration.yaml
http:
base_url: my-domain.duckdns.org
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
Duckdns config
lets_encrypt:
accept_terms: true
certfile: fullchain.pem
keyfile: privkey.pem
token: My_token
domains:
- my-domain.duckdns.org
seconds: 300
Duckdns Logging
# INFO: Using main config file /data/workdir/config
+ Account already registered!
[22:00:46] INFO: OK
MY_IP_ADDRESS
NOCHANGE
Processing my-domain.duckdns.org
+ Checking domain name(s) of existing cert... unchanged.
+ Checking expire date of existing cert...
+ Valid till Jul 30 14:43:33 2020 GMT Certificate will not expire
(Longer than 30 days). Skipping renew!
[22:06:01] INFO: OK
MY_IP_ADDRESS
NOCHANGE
Does anyone have a clue what might be the issue?
