I used Duck DNS to provide a static IP address and forwarded my 2 ports to the new Duck DNS domain. Check in canyouseeme.org and everything was working. Duck DNS created 2 pem files, “fullchain.pem” and “privkey.pem” in my “ssl” folder on the home assistant os. Per the instructions, you put the following lines in you configuration.yaml file and then you access HA using the https:// prefix instead of just http://.
I check the configuration and receive a “Configuration Valid” result. When I reboot the RPi, I cannot access the GUI using either https:\\ [IP Address of my RPi] or http:\\ [IP Address of my RPi]. I can ping the RPi and open the configuration.yaml file to comment out the new code but no GUI. Once I have commented out the new code, everything works again.
What am I doing wrong?
Update:
Working now. Not sure what I did differently but I may have been forgetting to append :8123 to https://192.168.1.141
Got it working on my phone over the cell network as well.
Thanks everyone for helping a noob! Once I get more proficient I hope to be able to help others as well. What a great community this is!
First, you are not using the editor‘s code block (</>) when posting configuration and 2nd: Is /ssl a path on the host or inside Home Assistant container?
Without the new code I can access the GUI with “http://homeassistant.local:8123” so I put the following lines in my configuration.yaml file and still no joy:
you have to use host.domain.xxx format.
so for example if you used to access this http://192.168.1.1:8123
you now have to access https://hass.mydomain.com:8123 (RPI’s host name then DOT then your domain:8123)
log into your RPI and see what you called it.
user@host format
so mine is hass@hass because i’m logged in as user hass and the hostname of my OS is hass (clever i know ) lol
I followed a you tube video which showed how to do this and on their local network they were able to use https:// and the ip address of the RPi appended with :8123 to reach the GUI. in my case that is https://192.168.1.141:8123
You should be able to, it will throw a cert error though. Of you have the security settings turned up on your browser it may not even load the page.
Personally I would just set up nginx instead of ha serving the Https stuff.
By the time the video gets to YouTube it’s usually out of date.
The docs for home assistant are kept up to date as things change and new ways to do things are developed.
