I have seen many problems with this error, but when creating an automation, and I am not having luck reading the answers. I would like to create a new script, but cannot add one as I keep getting this Message malformed: Integration ‘’ not found error.
I have also tried through yaml:
configuration.yaml has the following:
script: !include scripts.yaml
and then scripts.yaml has the following:
testscript:
alias: Test scripting in YAML
description: "Linda se eerste toets script"
sequence:
- alias: Toggle living room
service: switch.turn_on
data: {}
entity_id: switch.10009f5995
This does not show up as a script on the UI, neither can I add a card to the overview with as it does not pick up the script. That’s when I tried to add the script with the UI, but keep getting this error. I have made sure the indentation is correct.
Any help will be appreciated, I am a complete beginner.
