I have an automation for my boiler that I want to turn off after specific time depends on the switch that I turned it on. Also I want to be able to turn it off from the switch. So far so good, does the job as I like it. The “problem” is that when I turn off manually the boiler, the automation cancel itself and run again just to pass the “choose” state and turn the boiler off
It doesn’t bother me much but it doesn’t seems right that way. Is there any way to turn it off manually and the automation don’t has to start again from the beginning? Probably I have to play with that template thing but I don’t understand this.
I tried that but its the same. It keeps cancel the automation and triggers it again just to turn off the boiler. The problem is with the service calls “off”.
As for the delays, I know that there may be an issue but it won’t make any problem for now. I will fix it sometime.
By the time passed or by the switch. But when I turn it off by the switch, cancel the current run of the automation and run it again to bypass the choose options. Just like the photos with the timeline. They only have few seconds difference
OΚ maybe it’s not an issue after all. I thought it was weird that the automation has to stop when I turn off the switch and run again. Anyway, thank you for your time
