Hi, i have made my all my lights automations in Node-Red. It has worked for several years without any problems. but now recently when i turn off the lights supervisor immediately turns them back on. I don’t understand why this happened are more here with this problem? or how do I solve this?
I’m not using Node-Red, bit I had a similar problem, turning all light groups on after turning off. Reason was an accidental activated automation that trigger was a time pattern.
I know this is old but had a similar issue where the supervisor turned on some switches randomly. If you trigger something from Node red then it does indeed say the supervisor turns it on or off.
I had several privacy switches turned on randomly on my ubiquiti cameras by the supervisor. All by themselves with no node red code talking to those switches.
Maybe I found the solution in my case. I had recently installed the Genie add-on. (The open-source, privacy-preserving voice assistant.) and I think that caused the problem. Although I did not used it, I think that was the one switching on the light. I had disabled the addon and in the last two days I do not have this problem.
