I’m in the process of building a solar powered light for a spot in the garden. The solar panels are big enough to support a RGB LED with 1~2w through the night and recharge the next day.
The controller node is a D1 mini and, for good measure I added some sensors in the process. As to not be too wasteful with the limited energy (the light is the most important), the controller will be on deep sleep, waking every 5 minutes to send the sensor data and receive the light commands.
The problem arives on that last bit: receiving the ligth commands. Most of what I have read comes in the way of sincronizing the state shown in HA to match what is in the node, but I can’t figure out a way to do the contrary and have a “dummy light” in HA that has it’s state mirroed by the node when it wakes up.
Another Idea could be going full custom with helper inputs, but that would require loads of automations and would take out the simplicity of just turning on a light on the ui that I am looking for.
I would appreciate any other ideas on how to implement this.
Thanks in advance!
