When item is =! 'play' for X time do Y
Hi, I’m trying to achieve this :
When media_player.spotify is =! ‘play’ for X time do Y
Since I want a ‘is not’ I think I should use a template but then I can’t use the ‘for…’
If I’m not clear I want to do something like
- alias: tab_salon_auto
    platform: state
    entity_id: media_player.nvidiashield
    to: NOT 'play' #THIS IS HERE I NEED HELP
    for:
      hours: 1
      minutes: 10
      seconds: 5
    service: shell_command.stop
here ya go.
 - condition: template
    value_template: "{{ states.media_player.nvidiashield.attributes.state != 'play' }}"
Not true anymore. I added the for: option to the template trigger in 0.95. And in 0.96 I added template support so you can use a template in the for: option if you want. See: Automation Trigger - Home Assistant
I don’t use media_player’s, so not sure. Is the state ‘play’, or is it in an attribute that you see that? Assuming it is the state:
    platform: template
    value_template: "{{ not is_state('media_player.nvidiashield', 'play') }}"
    for:
      hours: 1
      minutes: 10
      seconds: 5
Oh cool thank you !
I’m still in 0.95 ( I need to update but I saw that break something and I was not ready to fix it so I wait )
so you tell me as soon as I update to 0.96 it’s gonna work ?
The above will work in 0.95, which is when I added the for: option itself to the template trigger. In 0.96 I added the ability to use a template in the for: option. (I.e., in 0.96 you can use templates in the template trigger in both value_template: and for:.) Since you’re not using a template in the for: option you don’t need to wait for 0.96.
I did not know this! This makes you my hero!
