When my esphome devices loose wifi, they start rebooting, which 'flicks' the relay
I have this is my config:
  on_boot:
    then:
      - switch.turn_on: relay
On quite a few items, but this causes the relay to ‘flick’ off/on when it reboots. As it keeps rebooting if I work on the network, and the wifi is gone, it will make this flicker every few minuttes.
I would very much like to keep the possibility to have the items ‘always on’ after a boot, but at the same time I don’t want them to do the flick, as at some point some switchmode psu are going to die from this.
So is there a way to modify the ‘on_boot’ so that it only turns the relay on, if it’s off?
Untested, but I think this is how to do it:
  on_boot:
    then:
      - if:
          condition:
            - switch.is_off: relay
          then:
Doc: https://esphome.io/guides/automations.html?highlight=automation#if-action
as an alternative:
restore_mode: RESTORE_DEFAULT_ON
will restore it’s previous state and if previous state isn’t known, it will turn the switch on. Wifi dropouts shouldnt wipe the state whereas powerloss will do.
check
and for setting a higher reboot timeout:
Of course! I use that. Just forgot all about it.
Much simpler.
That’s great, thanks, I’ll use that!
And it seems to work, that’s great. :slight_smile:
How did you test this exactly? I’m trying to use a Blitzwolf BW-6 as a “measure only” plug. If I kick the plug from the wifi network it still toggles off the relay and turns it back on a few seconds later.
I disabled the reboot, and set the
for the pin tha toggles the switch.
What sort of device do you have? Maybe it simply works in a different way than my BW-6
I have the house full of BW-6 :slight_smile:
My configs looks like this
substitutions:
  device_name: adrianentertainment
  # Higher value gives lower watt readout
  current_res: '0.00290'
  # Lower value gives lower voltage readout
  voltage_div: '940'
esphome:
  platform: ESP8266
  board: esp8285
wifi:
  ssid: "NOT"
  password: "WIFIPW"
  reboot_timeout: 60min
  manual_ip:
    static_ip: 10.11.13.40
    gateway: 10.11.13.1
    subnet: 255.255.255.0
#  use_address: 10.11.12.201
  fast_connect: true
  ap:
    ssid: "${device_name} Hotspot"
    password: "HOTSPOTPW"
logger:
  baud_rate: 0
api:
ota:
  password: "OTAPW"
time:
  - platform: homeassistant
text_sensor:
  - platform: version
    name: "${device_name} ESPHome Version"
  - platform: wifi_info
    ip_address:
    ssid:
binary_sensor:
  - platform: gpio
    internal: true
    pin:
      number: GPIO13
    on_press:
      - switch.toggle: relay
output:
  - platform: gpio
    pin: GPIO00
    inverted: true
switch:
  - platform: gpio
    pin: GPIO15
    on_turn_on:
      - output.turn_on: led
    on_turn_off:
      - output.turn_off: led
status_led:
  pin:
    number: GPIO02
    inverted: true
  - platform: wifi_signal
    name: '${device_name} wifi signal'
    update_interval: 60s
    accuracy_decimals: 0
  - platform: uptime
    unit_of_measurement: days
    update_interval: 300s
    accuracy_decimals: 1
    filters:
      - multiply: 0.000011574
  - platform: hlw8012
    sel_pin:
      number: GPIO12
      inverted: true
    cf_pin: GPIO05
    cf1_pin: GPIO14
    current_resistor: ${current_res}
    voltage_divider: ${voltage_div}
    current:
      unit_of_measurement: 'A'
      accuracy_decimals: 3
      icon: mdi:flash-outline
    voltage:
      unit_of_measurement: 'V'
    power:
      unit_of_measurement: 'kW'
      accuracy_decimals: 5
      filters:
        - multiply: 0.001
    change_mode_every: 4
    update_interval: 10s
  - platform: total_daily_energy
    name: '${device_name} daily energy'
    power_id: power
    unit_of_measurement: kWh
Though, on this one I haven’t reconfigured the reboot.
Ah, well if it works for you it should work here too :slight_smile:
I do see some differences here and there, I’ll have to tweak my config then.
In my tests this afternoon it kept on toggling the relay, also the restore_mode didn’t seem to deal with the LED
hmm mine never turns off, even survives firmware updates, even tho I can hear the click, I guess it comes from ALWAYS_ON and inverted pin, maybe it helps you!
Thanks, that did help. The relay does indeed appear to stay on in all cases (flash, reboot).
I do hear the relay clicking when the BW-6 reboots (e.g. after flashing new firmware) but the device itself (as a test; another BW-6 with the LED on) seems to stay on.
The only downside is that the LED doesn’t go on upon boot, but that can probably be solved some way. I do like the “feedback” it provides.
Also didn’t know that the api also has a reboot_timeout parameter. That explains why the relay turned off before when my HASS was down for a bit :sweat_smile:
Hmmm check my integration’s Blue LED light and the binary sensor. The blue led should have the same state as the relay, except when you press the device button manually. I have commented out the ability to switch the relay because I was pressing it by accident a couple of times. it turns back on after a reboot.
The red led is exposed as a powerindicator it turns on when a certain value is reached.
