When we have multiple netatmo houses: allow to select only one to be exposed in home assistant
I do have 2 homes connected into my Legrand/Netatmo account, but there is no way to only import one of those house into my homeassistant instance for a given house, the today integration creates all entities for all the available houses in netatmo/legrand.
Thanks for this great integration!
BR
Thomas
I have the same problem, duplex house, 2 netamo accounts, I want to add the both to the same home assistant. Is it possible?
it is actually the reverse problem you have : I have two house under the same netatmo account … and I see them both in home assistant :slight_smile: and I would like to see only one!
Meaning that if you put your two houses under the same netatmo account you would see both in homeassistant
