Where advanced options
I don’t found the advanced options for reboot or shutdown system:
I have HA container core-2023.4.5
Thanks for tour help
I search this:
I understand. The lower two options are only available if you’re running the Home Assistant OS. It doesn’t apply to containers.
It is possible to use the options in systems with a supported supervisor, so supervised setups will have it available too.
Ok, thanks. So, is it reboot system = reboot HA docker?
Restarts the container rather than docker itself, I’d imagine. I run HA in a container on my Synology NAS alongside lots of other containers, and the restart option does not affect the others — fortunately!
Docker is a container system, so restart docker and restart container are the same.
Restart system/host is restart of the entire host, ie. all docker containers and main OS.
This is somewhat equal to pulling the power.
