Hi, folks,
I created a very simple alert Alert - Home Assistant (home-assistant.io). It’s pretty much a copy of the example in the page, but it doesn’t work.
I also cannot find any logs. Where should I be looking for these logs?
Hi, folks,
Settings → System → Logs
There is no “Alert” log. But the Home Assistant Core logs should show any errors that occurred.
Thanks, Tom.
Hm, ok, my alert didn’t work due to the fact I used the wrong notify entity, but there was nothing in the logs, just a quiet phone . I managed to find the error by trial but it would be better having some decent logs somewhere…
Well if it was a valid service it’s not an error and won’t be logged unless you change the logging level to “debug”. This is very chatty and not recommended for long term use.
Thanks - I was hoping for logs similarly to automations where also successfully triggered automations leave logs.
You mean traces?
No that is not available for Alerts.
