Where are my config files now?
I’ve jumped from a 0.79 version to the latest, and while slick, I’m a bit confused.
Where are my configs now? I have installed a couple of integrations from the UI but I cannot find them in yaml files
Some integrations just don’t work, so I put them again in configuration.yaml (yeelight and xiaomi_miio for a vacuum)
My automations, luckily are in my old automations.yaml, but it is confusing, I cannot set properties all properties if I use a device from integrations, but I get back my old automations by calling a service with an entity.
Areas are a mistery, since they seems to work only for integrations… how I can “assign” a device to a room? (I now I can set the in lovelace but it’s bothering me to see areas in some entity and in others not)
I’m using mqtt autodiscovery with zigbee2mqtt, where are the discovered entities written? if I config permit_join false can I have a static file with all my entities mapped?
also there is one that is not getting the friendly_name that is setup by z2m and continues to refer to it is id, how can I change it?
Is there a way to get rid of integrations and return to old yaml files?
My setup is working right now, and I’m happy of the progresses of home-assistant ,but this situation is puzzling me, since I don’t know how can I put my config to git and configure an ansible script to setup a full recovery
THey aren’t in yaml files. You shouldn’t need to ‘reconfigure’ or change anything. If it doesn’t work, then remove the integration and start again.
check your log for errors with yeelight and xiamo_miio. You can also see the logs in the UI through Configuration → logs.
I don’t know what you mean by this. If you’re using the automation editor, you can switch from a device trigger to a state trigger, etc. Device triggers are just a new trigger method. If it doesn’t do what you want to do, switch to another trigger type.
You can’t. It needs to come from an integration in order to assign to an area. Areas pretty much only auto generate your UI, like groups did in the old interface. You can take control of your interface and completely ignore areas.
auto discovered items are placed in .storage. A hidden folder inside your config. Be warned, these are not yaml files and they are not meant to be altered.
Sorry, don’t know the answer
Change it through the UI. Either through customizations or go to the integration and click on entities and adjust it there.
No.
Use snapshots. But this depends on what installation method you chose. What did you use?
Also, if you really want to use git. Just pull your whole config folder. As I stated before, there’s hidden folders that contain this information inside your config folder.
it can be ok, but still I have yaml files with custom sensors and automations that depend on what the integration provide (and I have to dig inside the ui to find the entities provided by the integration)
No log from yeelight integration, just a generic ui error
and the xiaomi_miio integration wants to connect only to a mi gateway not the vacumm, that works fine using
vacuum:
  - platform: xiaomi_miio
what I mean is that working with the concept of devices from an integration limits what I can do with that component for example:
  - platform: sun
    event: sunset
  condition: []
  - service: light.turn_on
      transition: 600
      color_temp: 324
      brightness: 255
    entity_id: light.terrazzo
the data part over there is simply not available for a device, it is limited to just the brightness, so what is the purpose of exposing a device instead of the entity?
Which I’ll do, but I don’t like the inconsistency
which is why I would prefer to be able to add them by hand to a single yaml file after the first configuration
well it doesn’t change, homeassistant just reverts to the id everytime (z2m works fine with the friendly name)
And that is a very big regression, hiding configuration is not a great thing especially if autocofiguration is half backed and inconsistent like it is now, config file are just better
