Where are pihole files?
So I’m trying to access the whitelist and blacklist files but I can’t find it. I know that theorically they should be on /etc/pihole/whitelist.txt but the configurator addon doesn’t show that folder.
I’m sure they are there because when pihole starts it tells the directory:
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] permissions: applying...
[fix-attrs.d] permissions: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Hass.io Add-on: Pi-hole
 Network-wide ad blocking using your Hass.io instance
 Add-on version: 4.0.0
 You are running the latest version of this add-on.
 System: Ubuntu 18.04.3 LTS  (armv7 / raspberrypi3)
 Home Assistant version: 0.99.3
 Supervisor version: 189
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] patches.sh: executing...
[cont-init.d] patches.sh: exited 0.
[cont-init.d] pihole.sh: executing...
  [✓] Password Removed
[cont-init.d] pihole.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[15:14:53] INFO: Starting PHP-FPM...
[15:14:53] INFO: Starting Pi-Hole FTL...
[2019-10-02 15:14:53.827 718] Using log file /var/log/pihole-FTL.log
[2019-10-02 15:14:53.828 718] ########## FTL started! ##########
[2019-10-02 15:14:53.828 718] FTL branch: master
[2019-10-02 15:14:53.828 718] FTL version: v4.3.1
[2019-10-02 15:14:53.828 718] FTL commit: b60d63f-dirty
[2019-10-02 15:14:53.828 718] FTL date: 2019-05-25 21:37:26 +0200
[2019-10-02 15:14:53.828 718] FTL user: pihole
[2019-10-02 15:14:53.828 718] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-10-02 15:14:53.828 718]    SOCKET_LISTENING: only local
[2019-10-02 15:14:53.828 718]    AAAA_QUERY_ANALYSIS: Show AAAA queries
[2019-10-02 15:14:53.828 718]    MAXDBDAYS: max age for stored queries is 365 days
[2019-10-02 15:14:53.828 718]    RESOLVE_IPV6: Resolve IPv6 addresses
[2019-10-02 15:14:53.829 718]    RESOLVE_IPV4: Resolve IPv4 addresses
[2019-10-02 15:14:53.829 718]    DBINTERVAL: saving to DB file every minute
[2019-10-02 15:14:53.829 718]    DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-10-02 15:14:53.829 718]    MAXLOGAGE: Importing up to 24.0 hours of log data
[2019-10-02 15:14:53.829 718] Notice: Increasing privacy level from 0 to 1
[2019-10-02 15:14:53.829 718]    PRIVACYLEVEL: Set to 1
[2019-10-02 15:14:53.829 718]    IGNORE_LOCALHOST: Show queries from localhost
[2019-10-02 15:14:53.829 718]    BLOCKINGMODE: Null IPs for blocked domains
[2019-10-02 15:14:53.829 718]    ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2019-10-02 15:14:53.830 718]    DBIMPORT: Importing history from database
[2019-10-02 15:14:53.830 718]    PIDFILE: Using /var/run/pihole-FTL.pid
[2019-10-02 15:14:53.830 718]    PORTFILE: Using /var/run/pihole-FTL.port
[2019-10-02 15:14:53.830 718]    SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-10-02 15:14:53.830 718]    WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2019-10-02 15:14:53.830 718]    BLACKLISTFILE: Using /etc/pihole/black.list
[2019-10-02 15:14:53.830 718]    GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-10-02 15:14:53.830 718]    REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-10-02 15:14:53.830 718]    SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-10-02 15:14:53.831 718]    AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-10-02 15:14:53.831 718]    MACVENDORDB: Using /etc/pihole/macvendor.db
[2019-10-02 15:14:53.831 718]    PARSE_ARP_CACHE: Active
