Where are the mount points?
I’m running HA on a RPi5 booting on a SD with a SSD external HD (USB, set as data disk) and a backup linked on a NFS network share.
(Don’t ask “why not booting from ssd” : my RPi can’t - power problem ? - didn’t solve it)
I have a strange problem with backups :
  • When executing backups from an update process, the saving .tar file goes on the “data disk” (i assume it’s the ssd ?)
  • When the backup launched “manually”, the .tar file goes to the NFS share
Now, I’m looking for the mount points to understand and if possible, solve, but ssh’ing in HA, I can’t find a mount for the SSD nor the NFS. Does anybody know where they are ?
I also would like to backup the db’s (I have InfluxDB and MariaDB) but can’t find them.
Could someone help me ?
Home Assistant Add-on: Terminal & SSH
Installation
Follow these steps to get the add-on installed on your system:
  1. This add-on is only visible to “Advanced Mode” users. To enable advanced mode, go to Profile → and turn on Advanced Mode.
  2. Navigate in your Home Assistant frontend to SettingsAdd-onsAdd-on store.
  3. Find the “Terminal & SSH” add-on and click it.
  4. Click on the “INSTALL” button.
Once its running type:
ha hardware info
