I was playing with the UI editor, and can´t figure out (if at all) the yalm codes ar stored like regular yaml-files…
It would be nice to design most of, or a draft of the GUI in the UI editor, and then switch back to YAML mode and tweak it there for further costumizations.
Managing through the UI does not require a restart to display changes I believe YAML mode requires a restart.
The file(s) are likely in the .storage directory. If editing, I would only do that when HA is stopped.
YAML mode do not require a restart. Just save the changes and refresh the page in the browser. In some cases you will have to do a Refresh/Update from the upper right menu to see the changes.
Even if stored in JSON, where can they be found? I seemed to have screwed something up while adding a custom card, and now going to any lovelace page at all freezes my browser windo until the browser asks to stop loading the page.
I’d like to just remove the part where I entered the resource in raw mode, but can’t get to that…
