So I’m totally new to Home Assistant, and have a real noob question. I’m not sure whether the problem is that I can’t figure out how to naviate in HA, or if there are some pre-reqs for the ConBee2 that I’m missing.
I have installed hassio on a RPI and I’m trying to setup my ConBee 2, which also is connected to the same RPI.
I have tried following the guide on: deCONZ - Home Assistant but I still don’t have success with it.
As I understand the guide, the conbee2 can be auto discovered, and if it isn’t I’ll have to install manually. If I goto configuration > devices, I can’t find anything about deconz or ConBee2, so I suppose I am to add it manually. When I click add integration and choose deconz, I’m asking about the IP and port number. Since the ConBee is connected to the RPI itself, I guess this must be the IP address of the RPI itself, the next dialogbox tells me to goto deCONZ settings > Gateway > Advanced and press authenticate.
This is when I’m totally lost. Should I be able to find these settings inside Home Assistant - and if so, where can I find it - or am I supposed to install some other software somewhere else to get these settings ?
