Where can you put variables in your automation and state based trigger templates and template sensors
Can anybody tell where you can put a variables definition in:
  • automations
  • template sensors
  • template triggers
Reason for asking:
I’ve been searching for an answer in the documentation and could not find it.
Same goes as to where you can import jinja macro’s and where you can’t.
I would like to know because I now seem to have gotten stuck in:
  • not being able to import a jinja macro in a state based trigger action variable (is that correct?)
  • not being able to define variables in a template sensor (while I can import the macro there, but I need the result at several places maybe in my state based trigger action as well)
Some background on what I’m trying to achieve.
I got a magic cube from Aqara.
A really nice remote with one flaw:
The rotate events lack information which face of the cube was activated.
Worse case: if the cube was asleep and you flip it, this flip event might get lost and your cube rotation might be interpretated under the assumption that the previous face (kept in my sensor) was still facing up.
Hence, I’ve written a macro to determine from the events that do contain the activated face, which face is currently up:
{% macro cube_face(cube_event, faces) %}
{% set is_cube_event = cube_event is defined and cube_event.event_type == 'zha_event' and cube_event.data.command in ['slide','knock','flip'] %}
{% if is_cube_event and cube_event.data.command == 'flip' %}
  {% set face_number = cube_event.data.args.activated_face | int | default(0) %}
  {% if face_number > 0 and face_number <= faces | length %}
    {{ faces[face_number-1] }}
  {% else %}
    {{ 'no face' }}
  {% endif %}
{% elif is_cube_event and cube_event.data.command in ['slide','knock'] %}
  {% if face_number == 0 or face_number > faces | length %}
    {{ 'no face' }}
  {% elif face_number in [1,4] %}
  {% elif face_number in [2,3] %}
    {{ faces[face_number+2] }}
  {% else %}
    {{ faces[face_number-4] }}
  {% endif %}
{% else %}
{% endif %}
{% endmacro %}
In my sensor I use this macro to update the activated face and would like to know which face that is to set my attributes (still a work in progress):
- trigger:
  - platform: event
    event_type: zha_event
    - variables:
        woonkamer_cube_event: >
          {{ trigger.event is defined and
             trigger.event.event_type == 'zha_event' and
             trigger.event.data.device_id == '5517cc098da2aa72bd77fe7e06a3776f' and
             trigger.event.data.command in ['slide','rotate_left','rotate_right','knock','flip','shake'] }}
        woonkamer_cube_reset: >
          {{ (woonkamer_cube_event and
             state_attr('sensor.woonkamer_magic_cube','command') == 'shake' and
             trigger.event.data.command == 'shake') }}
        woonkamer_lights: >
          {{ ['light.dimmer_2_5','light.dimmer_2_3','light.dimmer_2_4'] }}
        woonkamer_default_light: 1
    - name: "Woonkamer magic cube"
      unique_id: woonkamer_magic_cube
      state: >
        {% from 'magic-cube.jinja' import cube_face %}
        {% set active_face = cube_face(trigger.event,['lights','audio','speakers','climate','power','curtains']) %}
        {% if woonkamer_cube_event and active_face != '' %}
        {{ active_face }}
        {% else %}
        {{ states('sensor.woonkamer_magic_cube') }}
        {% endif %}
      attributes:
        command: >
          {% if woonkamer_cube_event %}
            {{ trigger.event.data.command }}
          {% else %}
            {{ this.attributes.command }}
          {% endif %}
        relative_degrees: >
          {% if woonkamer_cube_event and 'rotate' in trigger.event.data.command %}
            {{ trigger.event.data.args.relative_degrees }}
          {% elif woonkamer_cube_event %}
            {{ 0.0 }}
          {% else %}
            {{ this.attributes.relative_degrees }}
          {% endif %}
        light: >
          {% if woonkamer_cube_reset or (this.state == 'lights' and trigger.event.data.command == 'shake') %}
          {% elif woonkamer_cube_event and this.state == 'lights' and (trigger.event.data.command == 'slide' or (this.attributes.light == '' and 'rotate' in trigger.event.data.command)) %}
            {% set index = woonkamer_lights.index(this.attributes.light) + 1 if this.attributes.light != none and this.attributes.light != '' else woonkamer_default_light %}
            {% if index < woonkamer_lights | length %}
              {{ woonkamer_lights[index] }}
            {% else %}
              {{ woonkamer_lights[0] }}
            {% endif %}
          {% else %}
            {{ this.attributes.light }}
          {% endif %}
        audio: >
          {% if woonkamer_cube_event and this.state == 'audio' and trigger.event.data.command not in ['shake','flip'] %}
            {{ 'manual' }}
          {% elif woonkamer_cube_reset or (this.state == 'audio' and trigger.event.data.command == 'shake') %}
            {{ 'auto' }}
          {% else %}
            {{ this.attributes.audio }}
          {% endif %}
        speakers: >
          {% if woonkamer_cube_event and this.state == 'speakers' and trigger.event.data.command not in ['shake','flip'] %}
            {{ 'manual' }}
          {% elif woonkamer_cube_reset or (this.state == 'speakers' and trigger.event.data.command == 'shake') %}
            {{ 'auto' }}
          {% else %}
            {{ this.attributes.speakers }}
          {% endif %}
        climate: >
          {% if woonkamer_cube_event and this.state == 'climate' and trigger.event.data.command not in ['shake','flip'] %}
            {{ 'manual' }}
          {% elif woonkamer_cube_reset or (this.state == 'climate' and trigger.event.data.command == 'shake') %}
            {{ 'auto' }}
          {% else %}
            {{ this.attributes.climate }}
          {% endif %}
        curtains: >
          {% if woonkamer_cube_event and this.state == 'curtains' and trigger.event.data.command not in ['shake','flip'] %}
            {{ 'manual' }}
          {% elif woonkamer_cube_reset or (this.state == 'curtains' and trigger.event.data.command == 'shake') %}
            {{ 'auto' }}
          {% else %}
            {{ this.attributes.curtains }}
          {% endif %}
        power: >
          {% if woonkamer_cube_event and this.state == 'power' and 'rotate' in trigger.event.data.command %}
            {% if this.attributes.power == 'bioscoop' %}
            {% else %}
              {{ 'bioscoop' }}
            {% endif %}
          {% elif woonkamer_cube_reset or (this.state == 'power' and trigger.event.data.command == 'shake') %}
          {% else %}
            {{ this.attributes.power }}
          {% endif %}
What I tried and failed to do is a cube_face variable to hold what I currently do to set state.
And use cube_face instead of this.state (which is old) to update my attributes.
This way, if the cube awakes I can for instance ignore all rotation events until one of the other events has occured to first determine for sure which face is up.
Automations:
YAML variables can be defined multiple places. Though all variables have script-wide scope, variables that are attached to a trigger that is not the initiating trigger, or those that are part of unused branches of Choose or If/Then actions will not be resolved.
trigger_variables:
  var_1: true #Only Limited Templates and static values allowed
    value_template: "{{ states('binary_sensor.x') | bool == var_1 }}"
    variables:
      var_2: "{{ false }}" #If you have multiple triggers, this value applies only when this specific trigger initiates the automation.
variables:
  var_3: "{{ true }}"
condition:
  - variables:
      var_4: "{{ true }}"
  - variables:
      var_5: "{{ true }}"
  - choose:
      - conditions:
          - condition: template
            value_template: "{{ var_2 }}"
        sequence:
          - variables:
              var_6: "{{ false }}" #This value only applies for this Option of the Choose action.
* Variables will be populated with values roughly in the order I have numbered above.
State-Based Template Sensors:
YAML variables aren’t really supported in state-based template sensors. You can use the sensor’s attributes to render and store values that are used in the state template. In most cases it would be better to just set up another template sensor instead of self-referencing attributes.
Trigger-Based Template Sensors:
YAML variables can be defined at the trigger, in a variables block, or in the action block of a trigger-based template sensor. These variables are available for use in the state template as well as any attribute templates. Variables will be populated with values roughly in the order I have numbered below.
  - platform: numeric_state
    entity_id: sun.sun
    attribute: elevation
    above: -4.0
    variables:
      var_1: "{{ now().day }}"
    entity_id: sun.sun
    below: -4.0
    variables:
      var_1: 1
variables:
  var_2: 2
  - variables:
      var_3: "{{ var_1 is even }}"
binary_sensor:
  - name: Example
    state: "{{ var_2 }}"
    attributes:
      day: |
        {% set prev = var_1 if this is undefined else this.attributes.day %}
        {{  iif(var_3, var_1, prev) }}
UPDATE:
2024-01-28: It is likely that there will be significant changes to variables for both State and Trigger-based Template sensors and binary sensors (and possibly other template entities) in the coming year as progress is being made toward expanding Template Blueprints.
The first thing to do is define your trigger more specifically. That trigger will fire for every ZHA event posted to the Event Bus.
Also, be aware that this.state is going to be the state of the sensor at the moment the trigger fires, not the state based on the rendering of the state template.
Many thnx, this was just that bit of information I needed!
I’m going to bookmark this, as it is the only place that now shows where you can use variables (and their scope!).
This is were I’m now and works like a charm, now I can start working on my attributes :sweat_smile:
- trigger:
  - platform: event
    event_data:
      device_id: 5517cc098da2aa72bd77fe7e06a3776f
    variables:
      active_face: >
        {% set face = cube_face(trigger.event,['lights','audio','speakers','climate','power','curtains']).strip() %}
        {{ face if face != '' else states('sensor.woonkamer_magic_cube') }}
      woonkamer_lights: >
      icon: mdi:cube-scan
      state: >
        {{ active_face }}
      attributes:
        command: >
          {% else %}
          {% endif %}
        relative_degrees: >
            {{ 0.0 }}
          {% else %}
          {% endif %}
        light: >
          {% if woonkamer_cube_reset or (active_face == 'lights' and trigger.event.data.command == 'shake') %}
          {% elif woonkamer_cube_event and active_face == 'lights' and (trigger.event.data.command == 'slide' or (this.attributes.light == '' and 'rotate' in trigger.event.data.command)) %}
            {% else %}
            {% endif %}
          {% else %}
          {% endif %}
        audio: >
          {% if woonkamer_cube_event and active_face == 'audio' and trigger.event.data.command not in ['shake','flip'] %}
            {{ 'manual' }}
          {% elif woonkamer_cube_reset or (active_face == 'audio' and trigger.event.data.command == 'shake') %}
            {{ 'auto' }}
          {% else %}
          {% endif %}
        speakers: >
          {% if woonkamer_cube_event and active_face == 'speakers' and trigger.event.data.command not in ['shake','flip'] %}
            {{ 'manual' }}
          {% elif woonkamer_cube_reset or (active_face == 'speakers' and trigger.event.data.command == 'shake') %}
            {{ 'auto' }}
          {% else %}
          {% endif %}
        climate: >
          {% if woonkamer_cube_event and active_face == 'climate' and trigger.event.data.command not in ['shake','flip'] %}
            {{ 'manual' }}
          {% elif woonkamer_cube_reset or (active_face == 'climate' and trigger.event.data.command == 'shake') %}
            {{ 'auto' }}
          {% else %}
          {% endif %}
        curtains: >
          {% if woonkamer_cube_event and active_face == 'curtains' and trigger.event.data.command not in ['shake','flip'] %}
            {{ 'manual' }}
          {% elif woonkamer_cube_reset or (active_face == 'curtains' and trigger.event.data.command == 'shake') %}
            {{ 'auto' }}
          {% else %}
          {% endif %}
        power: >
          {% if woonkamer_cube_event and active_face == 'power' and 'rotate' in trigger.event.data.command %}
            {% else %}
              {{ 'bioscoop' }}
            {% endif %}
          {% elif woonkamer_cube_reset or (active_face == 'power' and trigger.event.data.command == 'shake') %}
          {% else %}
          {% endif %}
And my macro which I had to update after upgrading (apparently a fix in HA or Aqara):
  • Core 2024.4.3
  • Supervisor 2024.04.0
  • Operating System 12.2
  • Frontend 20240404.2
{% if is_cube_event %}
  {% else %}
    {{ 'no face' }}
  {% endif %}
{% else %}
{% endif %}
{% endmacro %}
