just upgraded to .96.5 and config check seems to have moved…It isn’t on the configuration general screen. Where did it go…or do I have some unique problem?
You need to enable an advanced mode in your profile if you want to see that button.
thanks…mystery solved.
If you use the check box under @anatolyk’s post to mark it as solved this will assist people searching for the same problem.
