I have attached a Fantom 2 TB drive to my RPi3 running Hassio. When I click on the “hardware” button on the system tab of the hassio pane, it shows 2 drives /dev/sda1 and /dev/sda
When I did the update this morning, the drive spun up and if I click the ‘import from usb’ the drive also spins up. So Hassio knows it is there. I want to use the drive to store still images for a timelapse. I can’t seem to find any way to access it.
I have read the posts advising to add it via devices:, but that doesn’t work with Hassio. I have read the post that tells how to get to the os in developer mode, but that seems to be strongly discouraged.
As far as I know that’s not possible with a Hassio (ResinOS) installation. The replacement for it, HassOS plans on adding that sometime in the future (if I understand correctly): https://github.com/home-assistant/hassos/issues/89
It is possible to access the drives, however it is not trivial.
Mind if I ask how you are planning to access it?
I can try to explain but I want to understand the protocol (FTP? Terminal access? Samba?)
I need to store a fairly large number of photographs for around 24 hours. I want to have a camera on the end of my harvesting robot arm to take pictures of each plant at 10 minute intervals. I have 300 head of lettuce on each wall but that will grow to around 600. I am going to use machine vision to inspect each plant for deficiencies in water/nutrients/light. Then the photographs will be assembled into a timelapse video of the plant’s growth.
I was going to use a Pi Zero with a Picam to take the photos and then route them via MQTT to the RPi3 running Hassio. The USB HDD is attached to the RPi3. I have tried using cp to just transfer the files directly, but kept running into file permission problems.
I can’t seem to get a SAMBA share to work either. Transferring them to a computer on my network is an option but I would prefer a self contained solution.
I don’t really have a preference for how it is done, just get it done reliably. The traffic volume is fairly low so speed is not really an issue. The MQTT broker is already handling the data from the temperature, humidity, and CO2 sensors.
Hi! I just realized that I did not post the reply last time sorry…Here you go!
Hi! First of all wow, this is a very impressive project!
Judging from the description I would assume that you know the basics of Linux and Hass.IO as well and you would also be able to use simple git operations. Let me know if you need details in these topics and I will explain more.
So the drive is accessed by the Linux system running on your pi, that is why the drive spins up. Hass.IO add-ons can access the drives if they are explicitly asking for it. This is the good news part.
The bad news are that most add-ons will not do this because most people are probably not using external hard drives with their home assistant installs.
So the way you have to handle this is the following:
add the privileged section as well from the example above, the hass.io system will need this to access the drive
create the /share/mnt directory and mount the filesystem for this we will use
Putting it all together I realized that this is quite complicated. Let me know if you understand what I’ve wrote.
I actually started to create the fork I’ve mentioned above but got quite busy
I’ll try to work it out for you maybe in the near future however I can’t guarantee anytime soon. I’d suggest you to contact @frenck, who makes all these amazin community addons for hass.io, maybe he has something on his roadmap that supports accesing hard drives connected. Frenck, can you help us out here?
You need to use the terminal or SSH add-on. Log into the computer running HassOS and there create the directory and mount the drive, see this for some hints: https://youtu.be/PWo1xkE0sds
Hi, first of all, thanks for your help and sorry for my English.
I try to mount my HDD following your instructions and when I’ve done the point 4 in SSH I’ve obtained this error “mount: mounting /dev/sda1 on /share/mnt failed: No such file or directory”
I see the drive in hass.io -> system -> hardware
I create the addon for SAMBA modifying the file config.jason with
